What's the trick to getting the Locking Differential pedal to work?
Results 1 to 8 of 8
  1. #1
    Join Date
    Sep 2014
    Posts
    77
    GlenRock, PA
    Kioti DK40SE HST Ford 8N
    Default What's the trick to getting the Locking Differential pedal to work?
    Went to use the pedal to lock the differentials on my DK40SE and it won't budge. Doesn't move a bit.
    Could I be doing something wrong? wouldn't think so, manual says just to depress it to lock the differential.
    I was on a hill, if there is pressure on driveline can you still depress the pedal?
  2. #2
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Default Re: What's the trick to getting the Locking Differential pedal to work?
    You may need the rear to spin a bit to line up the gears.
    Murph
  3. #3
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,343
    Branson, Mo.
    Kioti DK35se Hydrostat
    Put moderate (not excessive) pressure on the pedal. About the weight of your leg. Move the tractor, it should depress and lock in. If not. Investigate.
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  4. #4
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    8,142
    Central Square, NY
    LS XR3037HC
    If you can't move the diff lock while operating on level ground It could be possible the diff lock linkage may be frozen or stuck from lack of use. That was the problem on 2 previous tractors I had. I hardly ever used the diff lock on both and when I went to use it the pedal wouldn't move. Mine was froze up from lack of use and lack of lube. It took 2 cans of penetrant oil and some vibration by tapping with a hammer to get it to free up.
  5. #5
    Elite Member Sysop's Avatar
    Join Date
    Jun 2013
    Posts
    3,060
    Fairmont, WV
    Mahindra 4035HST purchased 2013 - Craftsman 42" HST purchased 2003
    There are only a couple places within the rotation of the driveline it can lock in. If those places in the driveline are not lined up, as murphy said above you may need one of the tires to spin slightly before it will lock in.
    If you just want to test the functionality, as k0ua said put the weight of your leg on the pedal and proceed to drive in a circle using only 2wd. If you make a complete circle and it hasn't locked in, get it checked out. When driving in the circle, once it locks in the tire on the inside of the circle will begin to spin and the tractor will fight to go in a straight line. If that happens all is well.
  6. #6
    Join Date
    Sep 2014
    Posts
    77
    GlenRock, PA
    THanks guys, Tractor only has 12 hours on it, new this last Jan. I'll give it a try tomorrow when I get it back out to finish cleaning what I started.
    Clearing a hill side behind the house . Amazing what you can do with a grapple and a box blade
  7. #7
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    7,076
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds operating weight
    Has your snow melted ALREADY?
  8. #8
    Join Date
    Feb 2005
    Posts
    8,142
    Central Square, NY
    LS XR3037HC
    Quote Originally Posted by jeff9366 View Post
    Not completely melted here. I still have a pile about 6-8" in the yard where I had pushed it back. A couple weeks ago I back dragged the piles to help it melt faster.
    Attached Thumbnails Attached Thumbnails What's the trick to getting the Locking Differential pedal to work?-dscn1530-large-jpg   What's the trick to getting the Locking Differential pedal to work?-dscn1529-large-jpg
Similar Threads
  1. Differential locking pedal input
    By shortthrow50 in forum John Deere Owning/Operating
    Last Post: 05-18-2012, 03:45 PM
  2. Got a new (to me) MF 135, any trick to get it out of differential lock??
    By Bigd7400 in forum Massey Ferguson Classic/Vintage
    Last Post: 06-27-2011, 12:36 PM
  3. Traction Locking differential
    By jayg in forum Owning/Operating
    Last Post: 05-30-2011, 10:56 AM
  4. Trick to using differential lock on GC2310?
    By FredWalter in forum Massey Ferguson Owning/Operating
    Last Post: 12-14-2009, 10:07 AM
  5. Locking the differential.
    By Outbackfarm in forum Chinese Tractors
    Last Post: 04-07-2005, 12:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
