Remote control start
   / Remote control start #1
K man
Quadeville, ont
2014 Kioti CK 30 HST with cab. 2018 Cub Cadet Challenger 750 EPS UTV
This maybe a stupid question but is there such a thing as a remote starter for a tractor like you get on a car. Curious to hear from anyone about this. Please no insults just your input. :laughing:
   / Remote control start #2
Never heard of one;My tractor requires glow plug cycle and the clutch to be depressed to start.
   / Remote control start #3
The only remote starter I can think of is my wife when she leaves for work. Let me know how this works out for ya.... :)
   / Remote control start #4
Do they make remote starters for diesel automobiles that require a glow plug warming?
   / Remote control start #5
I have a remote start/ anti-theft device on my car and I am sure someone makes one for a diesel also. Have you done an internet search. If it works for a diesel car then it should work for a tractor. If one requires clutch to be engaged, then you would have to block it down when you park it.
   / Remote control start #6
On the CK20 there is a hold down for the clutch so you can start it without having to hold the clutch down with your foot. See picture below.
So based on this the clutch issue is not really an issue.
Rancho
   / Remote control start #7
my kubota has the same-ish hook, but I don't think it depresses it far enough for the clutch switch.
Obviously, it'd be easy enough to over ride...but that isn't necessarily the best idea either.
I'm not sure how "they" do it in manual trans diesel trucks.....
I could find no mention of diesel on Viper's webpage...
   / Remote control start #8
I have used this hold down hook to start my tractor without being seated on it, but since it is an HST, I am not concerned with it being in gear.
Rancho
   / Remote control start #9
I have a 08 Dodge Ram 2500 (cummins). Just installed remote start from Omega Link. It has setting for 15 second delay before starting. Not sure how you would get it to work on tractor.
Good luck.
Eddie
   / Remote control start #10
A better bet is probably a block heater. It would get you most of the benefits without burning the extra fuel or other drawbacks. Can easily get a remote controlled outlet cheaper & easier than remote start.
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A56435)
New Holland 1412...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
12' CONTAINER (A57193)
Honda UTV (A56859)
Honda UTV (A56859)
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55787)
Toro GreensMaster...
