PNWKioti
Hello fellow Kioti owners. Here's a little introduction. I've been lurking around for a few months, reading threads, researching my tractor purchase. In March, I pulled the trigger on a new 2510 HST FEL W/toothbar and a boxblade. This is my first tractor and I'm having a blast learning to master the art of using the FEL (I do believe its an art). I have 2.5 acres partially cleared with a gravel drive to maintain. So far, I've used the tractor to grade my drive (another art I'm going to need work on), and cleared a 45x35 spot for my garden. I dug out a lot of 3"-6" stumps as well as 3 in the 12-18" range...I think this would have been impossible without the toothbar btw.
Now the reason for my post. When I was doing my 10hr maintenance I found a few grease fitting that would not accept any grease. No biggy, I just removed a good one, installed it, greased the fitting and reinstalled the old fitting once it was lubed up. Problem is I cant find replacements at any of my local auto parts stores. Does anyone know the thread size of these Zerk fittings? I brought one with me to the store to match up and was told it was a 10mmx1, got home and it was a no go, too big. 8mm is definitely too small. I put a caliper on the org one and the 10mm, and there is about a .020 difference. Any help would be appreciated. I'm also having an issue shifting between high and low...ill save that for its own thread once I get a better idea what's happening.
Also, on a side note, I have a workshop manual. For those of you that don't and have questions that can be answered in the manual, feel free to ask!
