JimR
Elite Member
I found two more minor issues and will pass along the info to anyone that owns one of these tractors. First issue was the cooling line to the oil filter base. Mine was put on with a bit of a twist to the point where it was rubbing against a motor bolt behind the hose. I loosened the two clamps and spun the hose so that it was not pushing against the head of the bolt. Second issue is the radiator drain plug on the bottom right hand side of the radiator. Mine is cracking all the way around and will need to be replaced ASAP before it blows out on me. Mind you that this tractor is a 2015 leftover with only 89 hours on it now. I bought this in September of 2016. I hope the other rubber products on it don't start doing the same thing.
