CK3510 / CK4010
   / CK3510 / CK4010 #1
MaDiNfO
Portugal
Hinomoto E1802
Does any one know what kind of ECU does it have ?
And where is the odb2 port ? (photos?)
The tractors seam to b exactly the same would be nice to see if they can manage to be reprogrammed ie: CK3510 into a CK4010.
   / CK3510 / CK4010 #2
On my CK4010SE I believe it's to the right of the steering wheel above the pedals
   / CK3510 / CK4010 #3
There are a few other threads on this subject. I have an NX5010 and would like to unlock the control module for more more power. If you could do it, it would likely void your warranty if you had to take it in for a power train issue.
I don't know of anyone who knows how to do it.
If there is, speak up!
   / CK3510 / CK4010
I can do it in cars... don't know about tractors i never try ed before.. and i don't own a ECU controlled tractor...
Does anyone know brand and model of Kioti ECU's ? a picture would be nice.
   / CK3510 / CK4010 #5
For the ck3510HST, Isn't it located on top of the engine, mounted on a bracket? Made by Delphi, pn# F8600-26102
From Paige Tractors
Delphi DCM Light Duty Diesel Engine Controller Series
   / CK3510 / CK4010
Should be an easy read/write.
I am planing to buy one, if i do it i will let you guys know how it went.
   / CK3510 / CK4010 #7
The part I listed was for a ck35. I don't know what the ck40 part number is. If someone has the ck40 maybe they can provide a pic of their controller or just provide the numbers shown on the label. It could be the same base controller (FPGA) but programmed differently. It might be possible to reprogram a ck35 controller with the ck40 program but you would obviously need the ck40 specific program and the utility program that loads it.
   / CK3510 / CK4010
it is probably the same unit for sure.
actually i don't need the ck40 program to add a few hp to the ck35 :)
   / CK3510 / CK4010 #9
Someone would have to have the tractor on a dyno to verify the HP difference. Otherwise it's all speculation.
   / CK3510 / CK4010
i can do that here in Portugal...
