1st tractor; new CK3510SE
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Gold Member
    Join Date
    May 2017
    Posts
    446
    Pictou County, NS, Canada
    Kioti DS4110, Kubota GR2120
    Default Re: 1st tractor; new CK3510SE
    I think it may actually be the new version to replace the KL4010. At any rate you get an extra 100lbs of lift capacity.
  2. #12
    Join Date
    Aug 2013
    Posts
    110
    .... play safe and remember that the lord doesn’t count time spent tractoring against your total allotment. Very nice rig!
  3. #13
    Join Date
    Jan 2018
    Posts
    63
    New Braunfels, TX
    Kioti CK3510SE HC
    Quote Originally Posted by marchanna View Post
    Quote Originally Posted by Fuggley View Post
    .... play safe and remember that the lord doesn稚 count time spent tractoring against your total allotment. Very nice rig!
  4. #14
    Platinum Member grm61's Avatar
    Join Date
    Apr 2009
    Posts
    833
    Eastern Washington
    2013 Kioti DK45SE HST Cab
    Congratulations, on your new tractor! You wont regret that cab
    2013 Kioti DK45SE HST Cab, Loaded R4s, KL401 Loader with reversible cutting edge, KB2485 Backhoe with Mechanical Thumb
  5. #15
    Join Date
    Jan 2018
    Posts
    63
    New Braunfels, TX
    Kioti CK3510SE HC
    Quote Originally Posted by grm61 View Post
    Man you're not kidding! I put in 23 engine hours in 3 days clearing land. It's been hot, it's been cold, it's always windy I've been kicking up all kinds of dirt and dust. I've had a great time but I don't do this for a living, if it weren't for that cab I'd have been in the house!
    Here's almost a before, during and after shot of the 1st job. I forgot to get a true "before" shot, imagine the back left corner is full of crap too!
    1st tractor; new CK3510SE-pano_20180113_120301-jpg 1st tractor; new CK3510SE-pano_20180114_161419-jpg 1st tractor; new CK3510SE-pano_20180115_173931-jpg
  6. #16
    Veteran Member Peter 315's Avatar
    Join Date
    Mar 2016
    Posts
    1,432
    NH
    Kubota L3800 hst Kubota l47 tlb ( John Deere 770 sold )
    Quote Originally Posted by seijirou View Post
    You better slow down you will put yourself out of work
  7. #17
    Join Date
    Jan 2018
    Posts
    63
    New Braunfels, TX
    Kioti CK3510SE HC
    First issue popped up.
    While installing a radio I discovered I had no battery power at the radio plug. After talking with the dealer and looking at schematics we determined that the same power also feeds the dome light which I knew didn't work from day 1 and I had been assuming there wasn't a bulb in it and I had just ignored it, but sure enough there was no power to the dome light either.
    The dealer was able to point me to a connector under the left floorboard and when I checked it out it was full of water and corroded to the point that the pin for the power wire was actually gone. The connector is full of rubber seals so it really should be weather tight. I've never met perfect before though and things happen but the dealer is going to make it right and that's what counts in my book.
  8. #18
    Gold Member
    Join Date
    May 2017
    Posts
    446
    I知 a firm believer in dielectric grease on all electrical connectors. Keeps the water and corrosion out. One $10 tube will last you years and save you countless headaches.
  9. #19
    Join Date
    May 2009
    Posts
    76
    The pin that corrodes in the connector is a constant 12v power pin.
    Kioti Service has a kit with a new connector.
    They claim that the original connector points up and collects water and cleaning solution from pressure washing after unloading at the port..
    The new connector points down and self drains.
    Not sure I buy the complete story, but the failure is certainly caused by electrolysis, and the new connector seems to work.
  10. #20
    Join Date
    Jan 2018
    Posts
    63
    New Braunfels, TX
    Kioti CK3510SE HC
    Quote Originally Posted by finn1 View Post
    Ah that makes sense why the dealer knew exactly where to have me check then, sounds like it's a known problem.
Similar Threads
  1. Talk me out of a Kioti CK3510SE HC
    By seijirou in forum Buying/Pricing/Comparisons
    Last Post: 05-17-2018, 11:13 PM
  2. CK3510SE Block Heater
    By iflywhatevr in forum Kioti Owning/Operating
    Last Post: 01-11-2018, 11:55 PM
  3. Day 1 New CK3510SE HC 6.5 Hours and 1 Squawk
    Last Post: 12-20-2017, 01:05 PM
  4. Price Check CK3510SE HC
    By madvetos in forum Kioti Buying/Pricing
    Last Post: 10-31-2017, 08:30 PM
  5. OTD Pricing on the CK3510SE HC?
    By Cataclysm in forum Kioti Buying/Pricing
    Last Post: 04-17-2017, 03:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
