pdxkurt
Hey guys, I'm a new owner of a CK2610 HST and am getting used to its personality. The two things that I've noticed about it that "bother" me are
1) When I first start the tractor for the day and raise the RPMs to my normal operating levels of around 2k and engage the HST moving forward (slightly uphill) the tractor wants to die. If I release the pedal and ease into it again it will be a bit better, and then it will soon thereafter "warm up" and not behave in this way any longer. I have a FEL and either a backhoe or bush hog attached at all times. Is this a normal thing you guys experience?
2) I've seen this one mentioned and I'm not sure if I'm having a real problem or not, but I will notice that my HST pedals are slow to return to center, especially if I'm running with the pedal fully depressed, when I let off it will continue forward for a bit and slowly return to center and stop. I've seen others mention this and say the dealer replaced their HST. I called my dealer to ask about this and he said it was normal due to the amount of hydraulic fluid flowing through the system. Is this normal to an extent and other owners are experiencing a more serious behavior, or is this a legit concern I have?
Thanks!
Thanks!
