Lower radiator hose heater analysis, DK45se
   / Lower radiator hose heater analysis, DK45se #1
xcgreene
Down East Maine
2 Kioti DK45SEH's 1969 John D 2510
I've installed a lower radiator hose heater in one of my DK45se tractors.
Radiator hose size: 44mm OD, 34mm ID
Kats 16600, a 600Watt 1.5" in line heater, Slighly larger than what is needed, but its the best fit, and fits fine. ($37)
Plugged in over night, from about 8pm to 8am.
Ambient temp around 37F last night (certainly not the coldest, but data is relevent)
Here's a picture of the engine with temperatures and locations, taken with an IR gun after the 12 hours.
Notes:
*The heater itself cycles, I could hear a relay click inside. 110F cut in, 142F cut out.
*Most of the heat migrated towards the engine with this orientation, as you can see, the radiator top gathered little heat.
*After the heater, the highest temperatures were found at the water pump, the first stop after the heater. Steady at 117F.
*After the water pump, the heat migrated out to each cylinder jacket, as you can see the temp fades as the heat makes its way to the cylinder furthest aft.
*After the cylinders, the leftover heat sits just under the thermostat at around 78F.
*I was surprised to see a bit of heat in the oil sump as well, 61F.
*No modifications to thermostat, no holes drilled, just heater installed.
I plan to install a block heater ($80 from MIE) in the other DK45se, and do the same comparison. Though I feel this lower radiator heater option is the cheapest, most serviceable and convenient.
   / Lower radiator hose heater analysis, DK45se #2
Another comparison would be to do an hourly compression and see how long it takes to reach the same temperatures.
   / Lower radiator hose heater analysis, DK45se #3
Hourly comparison
Good idea, I'll do this.
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2019 JOHN DEERE 17G EXCAVATOR (A52707)
2019 JOHN DEERE...
2014 Chevrolet Traverse 2LT SUV (A55853)
2014 Chevrolet...
J BAR 6' BOOM POLE (A57192)
J BAR 6' BOOM POLE...
1996 FORD F-SERIES FLATBED TRUCK (A57192)
1996 FORD F-SERIES...
