Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kioti > Kioti Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-04-2004, 05:35 PM   #1 (permalink)
Default 3504 KIOTI CLUTCH PROBLEM?
I bought a used Kioti 3504 with 370 hrs. When I bought the tractor the previous owner said he had to replace the cluch and the new one had only 20 hrs on it. After 10 hrs of use the tractor stopped moving. I took the tractor to a Kioti dealership and they ended up replacing the clutch and pressure plates. After mowing for 6 hrs the tractor stopped again. Looking for any suggestions on what could be causing this problem.
HARKNESS is offline   Reply With Quote
Old 09-04-2004, 08:14 PM   #2 (permalink)
Default Re: 3504 KIOTI CLUTCH PROBLEM?
Sorry to hear about your problem.
Also sorry I'm of no help, because I have no idea what is causing your problem.
I do hope it gets resolved so you can start to enjoy your machine !!
DK35vince is offline   Reply With Quote
Old 09-04-2004, 08:20 PM   #3 (permalink)
Super Member
JerryG's Avatar
Send a message via Yahoo to JerryG
One question. Do you smell anything when you are mowing?
JerryG is offline   Reply With Quote
Old 09-05-2004, 09:13 AM   #4 (permalink)
I do not remember anything smelling unusual at the time. What would be the problem if there was a unusual smell? Thanks for the help.
Old 09-05-2004, 09:49 AM   #5 (permalink)
Super Member
JerryG's Avatar
If the clutch was actually being used up (the faces being worn out) that quickly, there would have to be a burn smell. Did you get to see the clutch, that they removed the last time? If there wasn't a burn smell, there MAY be as hub problem on the disk. It could have the wrong center or even be put in backward. You would have to see the disk, to be able to make that determination.
Old 09-05-2004, 01:00 PM   #6 (permalink)
When I took the tractor in the first time they showed me the clutch. The clutch was actually ripped off the hub, the rivets holding the two together were all rounded out. Also they found a bolt that and fallen off a finger? I was hoping by taking it to a dealer that they would know how to repair/install it correctly.
Old 09-05-2004, 03:17 PM   #7 (permalink)
Super Member
JerryG's Avatar
Sounds like they are using the wrong disk or pressure plate.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
