4 Wheel Drive Difficult to Change to 2 Wheel
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Member
    Join Date
    Mar 2005
    Posts
    39
    Alton, Missouri Oregon County
    DK45C
    Default 4 Wheel Drive Difficult to Change to 2 Wheel
    I have a new DK45C with 12 hours that I find very difficult to change from 4 wheel drive back to 2 wheel. The push pull stick does not want to pull back up when engaged in 4 wheel drive. Any suggestions?
    J D
  2. #2
    Join Date
    Jan 2004
    Posts
    5,974
    Default Re: 4 Wheel Drive Difficult to Change to 2 Wheel
    First, lubricate the linkage with WD40 or, I prefer, PB Blaster. Just follow the linkage under the tractor and spray the heck out of all of it. While you're under the body looking, have someone move the lever for you so you can trace the path.
    It should be much easier to do afterward. Sometimes it's necessary to move the tractor either a little forward or backward also and then try changing. If you have a loader, and it still sticks some after spraying, lift the front just a bit and then change it.
    If it's really too hard after that, have your dealer look at it as something is not right. John
  3. #3
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    40,760
    Texas
    </font><font color="blue" class="small">( difficult to change from 4 wheel drive back to 2 wheel )</font>
    Not an unusual problem at all. You can usually get the stick to pull back easily one of two ways: back up a bit, perhaps even turning the steering wheel, or tilt the FEL bucket forward, lower it to the ground, and lift the front wheels. Either way should relieve the "wind up" pressure or tension on the gears and let it shift out easily and smoothly.
  4. #4
    Elite Member GerardC's Avatar
    Join Date
    Mar 2004
    Posts
    2,606
    New York
    KIOTI CK20 GEAR.
    <font color="blue"> The push pull stick does not want to pull back up when engaged in 4 wheel drive. Any suggestions? </font>
    My CK20 does the same thing sometimes. I just move a little bit in either direction and she slips right in/out.
  5. #5
    Join Date
    Oct 2002
    Posts
    238
    Connecticut
    Kioti LK2554
    One other thing to check, is to make sure the tires on each side have the same air pressure. slight diameter differences can make it difficult to disengage.
  6. #6
    Join Date
    Mar 2005
    Posts
    1,861
    Erie, Pennsylvania
    Kioti CK30HST
    I have a new CK30. It's a little stiff even after lubing all the linkage points but it's getting better the more times it's shifted. It reminds me of an old 4WD truck I had. It's all gears and with pressure on them, it's hard. The trick I used with the truck works great with the CK. Similar to what KiotiJohn, Bird, and GerardC suggested. Move it slightly or barely slip the clutch for a second in the opposite direction. You don't need much. Just enough to relieve the tension on the gears. Sometimes, moving the shift control the last second before the tractor stops rolling works. Have fun with the new DK45.
  7. #7
    Member
    Join Date
    Mar 2005
    Posts
    39
    DK45C
    Thanks for the ideas from all who responded. I will try some to see which work the best.
    J D
  8. #8
    Join Date
    Mar 2004
    Posts
    2,606
    New York
    KIOTI CK20 GEAR.
    </font><font color="blue" class="small">( Thanks for the ideas from all who responded. I will try some to see which work the best. J D )</font>
    Let us know how you make out.
  9. #9
    Member
    Join Date
    Mar 2005
    Posts
    39
    DK45C
    I finally go around to trying the suggested solutions to the 4 wheel drive engaement/disengagement. Lifted the front wheels off the ground with the FEL and PRESTO the lever was easy to pull. Thanks for the suggestions.
    [img]/forums/images/graemlins/grin.gif[/img]
    J D
  10. #10
    Join Date
    Jan 2004
    Posts
    5,974
    </font><font color="blue" class="small">( I finally go around to trying the suggested solutions to the 4 wheel drive engaement/disengagement. Lifted the front wheels off the ground with the FEL and PRESTO the lever was easy to pull. Thanks for the suggestions.J D )</font>
    make sure you also use the PB Blaster on the linkage, and reposition the tractor, you may not have to lift it.
    Glad to hear it's working well.
    John
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
