DirtHauler
Gold Member
- Joined
- Nov 22, 2004
- Messages
- 462
- Location
- Northern Cali ~~~ "Weed" Country
- Tractor
- " '06" Kioti CK30 2015 Mahindra 2555 shuttle 2019 Massey 1760M
Did my first full service on my CK20 @ 54 hrs. When I pulled the trans drain plug, I found this stuck to the magnet.
Think I should be concerned? Called Kioti NC service dept., explained what I had found, guess what they said.........
"It was probably dropped in there when it was being assembled" /forums/images/graemlins/confused.gif. Told him about the wear mark on it, like a gear or bearing, his responce; "It was probably on the floor and ran over with a fork lift, the use them when they assemble tractors" /forums/images/graemlins/confused.gif I think my right leg is alot longer now! The finale answer when asked if I should worry about running it..........." Run it till it breaks, then we'll fix it under warrenty" Ummmmm, wonder if Kioti has a loaner program? /forums/images/graemlins/smirk.gif
