1450 Loader
Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Aug 2006
    Posts
    1
    Vassar, KS
    Kioti DK 35 2002
    Default 1450 Loader
    I was removing my loader today and noticed that the cylinder on the left stopped moving while the one on the right contined to move. This was after I had removed the pins holding the loader to the tractor. I jockyed the stick around abit and finally got the cylinder to moveback and forth and then it would act up again. It seemed like once the cylinder on the right got done extending or retracting the one on the left would begin to cycle. I thought the two cylinders should be acting in unison moving the loader up and down, any ideas. Thanks abunch
  2. #2
    Super Member Highbeam's Avatar
    Join Date
    Feb 2005
    Posts
    5,039
    South Puget Sound, WA
    Kioti CK30HST
    Default Re: 1450 Loader
    Since the cylinders are connected hydraulicly the fluid will always find the path of least resistance and since the cylinders are not perfectly identical and the length of hose to each is different there will almost always be one cylinder that is easier to move than the other.
    Kioti CK30HST, FEL w/toothbar, 60" RC, 60" BB, PJ 10k trailer. Weekend warrior hauling 50 miles each way.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
