IslandTractor
Super Star Member
- Joined
- Sep 15, 2005
- Messages
- 16,647
- Location
- Prudence Island, RI
- Tractor
- 2007 Kioti DK40se HST, Woods BH
After getting tired of having my backhoe pull the tractor around all the time, I sprung for a set of "BigFoot" dirt pads. (see photos). In researching these I found it difficult to locate a dealer but finally (thanks to TBN) found that Little Tractor (Little Tractor and Equipment Company - Kioti tractors) stocked them. Not cheap (about $150 shipped) but very heavy duty (25lbs each), made of 3/8 steel, and easy to install (10 minutes) with all hardware included. I had pondered making up some of my own with angle iron but am glad I didn't as these are much better than what I could have cobbled together.
The difference in stability of the BH is pretty dramatic. I was using them Friday on land that had just barely finished melting snow and was very soft. Still, the BigFoot pads kept me from needing to move the tractor except when I wanted to reposition by 90 degrees. In the past, I've found that even with brake set and FEL toothbar or grapple dug in for anchorage, that the BH had easily enough power to drag the tractor towards the stump or hole when digging. I'd have to dismount and reposition the tractor a number of times while stump grubbing. That got old fast. With the BigFoot pads in place it is no longer necessary.
With the new pads, I was able to dig out seven fair sized stumps in about two hours and bagged a total of 15 in addition to moving them and filling in holes on a pleasant sunny spring day. In the very soft soil the pads would move maybe a foot over the course of 10-15 minutes digging but I imagine they will move less once the land dries out a bit. Overall a very satisfactory purchase and I would recommend them to others.
