Foozle
Hi everyone. I'll start off by saying this is my first posting to the forum and also would be my first tractor purchase, so I'm very green on these matters. As such, I'm looking for some advice from all the veterans out there. I have 35 acres of land, with roughly 1/2 pasture/lawn and 1/2 woods. Of the pasture/lawn, probably about 2 acres of lawn and the rest pasture. The lawn is fairly rough, so tractor damage, unless really severe, wouldn't be a concern of mine. Of the pasture land, about 2/3 is fenced off for livestock (goats currently) and 1/3 is hay field. Near the house, I have a couple 1/2 acre gardens as well. I'm attaching a satellite picture of the property, courtesy of Google Earth. If you haven't checked out Google Earth, it is pretty amazing and I'd suggest it, especially since it is free!
With that as background, I'm looking for a tractor that I can use to: 1) cut the lawn (I also have a riding lawn mower I can use around tight spots, so can use the tractor for the open areas); 2) roto-till my two gardens; 3) "bush-hog" the hay fields and pastures for when I can't find someone to make hay and for when the livestock can't keep up with the grass growth; 4) move dirt/much/whatever around the property; 5) potentially bale small square hay bales, if possible; 6) dig a small pond (probably a stretch, but I thought I'd throw in there); and finally 7) chase my wife around the property when I'm feeling feisty.
For further clarification on wants/needs, I have allergies to hay/dust/pollen/sunscreen, so a cab would seem to make sense to help in that department. The pond building, I'm assuming, is unrealistic for this sort of tractor unless I would get a back hoe and even then, it would probably take months to move enough dirt, but I'm curious if anyone has tried with the FEL or backhoe. Also, I'm told that if you get the cab you can't have the Kubota backhoe on the back --- seems odd they wouldn稚 make a compatible backhoe for the cabbed versions (John Deere does, I believe).
Regarding the hay making, I don't really want to spend a huge amount for such a small amount of hay fields, but if I could find a used small square bale setup, it might be worth it. Is this realistic for the B series and if not for the L40 Grand series in terms of power?
I've visited both my local Kubota and John Deere dealers and looked at the B3030 and L40 Grand series, and for John Deere the 3320. The 3320 seemed quieter and less "bumpy" than the Kubotas, but in comparing prices, it seems you get a lot more tractor for your money from a Kubota. For example, I was quoted $22,000 for the JD 3320 (cab), which is 32.5 hp and weighs 2200 lbs, compared to the L40 Grand 3540 (cab), which was also $22,000, but was 37 hp and weighs 3748 lbs. Am I missing something or do you get more tractor for the $ from Kubota? Also weighing against JD was the quality of the people at the dealership. They seemed too busy to help me much and in fact, I had to wait 3 days just to get a quote on the equipment, compared to getting a quote on the spot from the Kubota salesman.
Sticking to Kubota for now, my initial reaction was that the B3030 was nice and probably sufficient for most of my needs (unless I wanted to try the hay baling stuff), but the L40 3540 felt like a lot more tractor for only about $4,000 more. The B3030 also accommodates a belly mower pretty easily, which seemed appealing for cutting the lawn, but I could get a finishing mower for the L40 and do the same thing I suppose. Any thoughts on comparison of a belly mower with a finishing mower? The attachments for the L40 run a bit more than the B3030, but you get a bit more for the money, like an extra 1 foot on the bush hog, more lifting power on the FEL, etc.
Other random thoughts/questions. What is ideal HP for the L40 Series? It comes in 3-cylinder (34-37 hp) or 4-cylinder (40.5-59 hp). The weight for all the models is roughly the same (in the 3748-4200 lb range). Seems like a really wide range of HP for one line of tractor. Is the 3 or 4 cylinder more appealing? Is the tractor underpowered at the lower end? Is the extra HP worth the extra $, even if you might not need currently but may need in the future? I got the following quotes for the tractor/cab only: L3540 - $22k, L3940 - $24k, L5240 - $28k, and L5740 - $30k. My initial reaction is that the extra $2k might be worth getting the 4 cylinder L3940, but jumping up to the L5240 for another $4k might not be worth it unless I had a compelling need for the extra HP.
Another question: For my first tractor, am I biting off more than I should with the L40 series if I go that way?
Regarding trailers - I probably don't need to haul around much, but may need to take the tractor in for service occasionally. Recommendations on types/sizes of trailers to look at?
Maybe a question I should post on the JD forum, but am I missing something in regard to the John Deeres?
Thanks in advance for the advice and I apologize for all the novice questions.
Dave
Dave
