Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kubota > Kubota Buying/Pricing
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 05-17-2008, 07:53 PM   #1 (permalink)
psdx's Avatar
Default B3030 - Front Blade Addition
Can someone tell me what the installation & removal time is for the B2791 quick hitch? Does a sub assembly get bolted on to stay? Then the rest goes on/off with pins, or what???? And if the B2755 72" blade is parked on a dolly is it one-person job to install & remove that as well? Thanks for your help.
__________________
Kubota B3030, LA403 FEL, Kubota ZD331-72, Woods RD6000 RFM, Woods RB72 Back Blade, King Kutter 5' Box Blade, Agric AL-50 Tiller
psdx is offline   Reply With Quote
Old 05-17-2008, 08:57 PM   #2 (permalink)
Gold Member
amigauser's Avatar
Default Re: B3030 - Front Blade Addition
Quote:
The quick hitch install take about 5 - 10 minutes max. Basically the rear of the quick hitch pins up to a permanently attached bracket. The front just hooks on the tractor frame below the brush guard and then is held with a screw clamp type assembly. A benefit of the rear quick hitch bracket is it acts like a skid plate to . The quick hitch can be attached with one person but it is easier due to its weight with a second person. You do not need to remove the front brush guard unlike the smaller BX series were you do. The blade itself just clicks into the quick hitch. I have my front blade on a dolly and it takes probably a minute to hook it up once the quick hitch is installed. There are four hydraulic lines, two from the quick hitch itself for up/down and two on the blade for left/right. They hook to the loader hydraulic control. The loader joystick is used to control up/down and left/right.
b3030-front-blade-addition-frame.jpg  b3030-front-blade-addition-bracket1.jpg  b3030-front-blade-addition-bracket2.jpg  b3030-front-blade-addition-quickhitch.jpg
__________________
Kubota B3030HSDCC, LA403 FEL, Kubota Quick Hitch and 6 Foot Front Blade, ATI Tooth Bar, ATI Tach-All, WR Long 3rd Function Kit, WR Long RBG2 48" grapple, Bradco Pallet Forks, JD 3pt Ballast Box, etc.
amigauser is offline   Reply With Quote
Old 05-18-2008, 08:04 PM   #3 (permalink)
BizDoc's Avatar
I've installed and uninstalled the sub-mount and blade by myself and it doesn't take much time, and isn't complicated at all. I have the blade at the back of the garage and either pull into it and hook it on or pull the pin, throw the lever and back out of it. The sub assembly comes off within minutes.
__________________
Kubota B3030HSDC: LA403 FEL w/ATI skid steer quick attach and Curtis 60" low profile bucket, B2775 six way front 72" blade on Kubota B2791 Quick Hitch Subframe, RC72-30B MMM 72", Loaded R-4 Tires.
BizDoc is offline   Reply With Quote
Old 05-19-2008, 08:00 AM   #4 (permalink)
AMR
Gold Member
The subframe can be a really easy one person install. I keep it on a dolly, if you don't it is pretty heavy to move around by yourself, roll it under the tractor and then lift it up to hook it on the front bumper. I then turn the tires full to one side and take a 3' long 2x4 to lever the back of the quick hitch up to the mounting hole in the tractor and slide the pin through, elapsed time, 5 minutes. I find the blade is actually harder to get on from the dolly than the hitch, it takes me some wiggling to get it on and off, hooking up the hoses and everything is about another 5 minutes for me. I love my front blade, I had a good winter with it last year, plus it tucks away pretty well in the garage.
AMR is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
