Results 1 to 5 of 5
  1. #1
    Gold Member
    Join Date
    Dec 2006
    Posts
    436
    Oakdale, TN
    Kubota M8540HD ROPS
    Default 540/1000 economy pto
    I'm looking at the M8540/M9540 tractors as I want to be able to make hay, including round bales. kubota shows a 540/1000 rpm PTO option availabe, dealer installed I believe. Does anyone have this option or want to comment on it?
    Deere offers economy PTO options where you can operate the engine at a lower rpm and use less fuel and produce less power but still get the correct pto speed. This would be used for situations that did not require the full engine power.
    I did not see an economy pto option for the M series, so I was wondering if the dual speed pto option could be used for this.
    Also, in looking at Kubota pto specifications it shows the pto output power for the tractor at 2600 engine rpm but to get a pto rpm of 540 the engine speed is about 2200 rpm. Any idea why they do this, and what the pto power might be at the 540 rpm pto speed?
  2. #2
    Join Date
    Aug 2007
    Posts
    750
    Default Re: 540/1000 economy pto
    My new holland has what they called an economy PTO also. It has a blue marked setting on the tach and a green one higher up in RPM. The blue one has an E next to it. It only puts out 540 RPM at the higher green mark though. I tried the economy setting with my swather and baler and it didn't like it. Some implements like my sprayer work fine on the slower speed though.
  3. #3
    Elite Member
    Join Date
    Sep 2003
    Posts
    4,160
    New Brunswick, Canada
    Kubota L5030 HSTC, MF 5455, Kubota M120, Allis Chalmers 7010
    WTA, the economy pto speed marked on your tach is meant to be used in conjunction with the e-pto gear shift. You would shift to e-pto (its like a 600 to 700 rpm pto gear) and reduce your engine rpms to bring the pto down to 540. If you don't have the e-pto gearing option you are just running them too slow.
    The 1000 rpm setting is too fast for most people to use as an economy pto. If you accidently ran your engine up a couple of hundred rpm over the right rpm for 540 you could blow apart your implement.
    Quote Originally Posted by WTA
  4. #4
    Elite Member rbargeron's Avatar
    Join Date
    May 2000
    Posts
    2,814
    MA
    L5450, L48, L3250, L345
    Quote Originally Posted by piller
    ......kubota shows a 540/1000 rpm PTO option availabe, dealer installed I believe. Does anyone have this option or want to comment on it?........
    I think the 2-speed pto option is very worthwile.
    540 has been the standard rpm for 3-point-hitch implements for a long time. In countries like Japan, Australia, N.Z. implements are also made for 750 and 1000 rpm. In the '70s and '80s tractors were imported here with 2-speed and even 3-speed ptos. But there is a danger in over-revving attachments and higher-speed pto's became less common on compact tractors.
    Having a 2-speed pto is very convenient - so its good to see it available again. Many implements don't need the full power of the tractor's engine and will run fine on a higher pto speed but lower engine rpm. There is even a small fuel saving because there's less engine friction at lower rpm. It makes perfect sense - cars don't need to run in low gear all the time either.
    Back in 2002, I converted my pto to 2-speed by adding factory parts for the Australia version of my Kubota. Story with pictures here.
    Re the last paragraph of your post, the engine, in the middle of it's power range, can make a given amount of power two ways - either at high rpm with low torque, or at low rpm with high torque. The sales brochure rates the pto horsepower at the rpm where the engine makes its maximum possible power. But the recommended rpm for pto work is lower and power available at that rpm would be a little less, the precise amount depending on the engine's torque/rpm curve. It makes it confusing because the marketers like to publish the biggest sounding numbers, where the engineers may be optimizing engine torque at the 540 pto speed.
  5. #5
    Gold Member
    Join Date
    Dec 2006
    Posts
    436
    Oakdale, TN
    Kubota M8540HD ROPS
    Thanks for the responses so far.
    Rbargeron: that was a very nice dual speed pto mod you made on your L5450! I enjoyed seeing the orange inside the gear box and your comments regarding the high quality of the kubota internals.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
