HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kubota > Kubota Buying/Pricing
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-01-2009, 11:38 PM   #21 (permalink)
Default Re: Six Lessons learned from shopping for a new 50hp Kubota Tractor
Quote:
Originally Posted by ultrarunner View Post
No Pictures?
Tractor is not being delivered until Monday afternoon...hopefully. It may end up being Tuesday afternoon if the driver is late making an earlier delivery into St. Louis Monday morning.
Kathy and I just got back from the farm where we spent the day making room for the new arrival in the shop building.
Will post pictures as soon as the tractor is home.
Need to find a larger brush hog now...
Owner's manual indicated that a 7' rotary cutter is the largest recommended weighing no more than 1200 lbs. I was expecting to go at least 8'. However they don't differentiate between a single gear box and a three gearbox cutter which would be much shorter and easier on the three point hydraulics.
Any opinions?
Kerry
__________________
2009 Kubota M5040HD 4WD w. Hydro Shuttle and FEL
Owenslee is offline   Reply With Quote
Old 11-02-2009, 12:22 AM   #22 (permalink)
Gold Member
Any opinions?
Kerry
Have you looked at the Woods Heritage Series?
TripleR is offline   Reply With Quote
Old 11-02-2009, 12:52 AM   #23 (permalink)
Quote:
I did but they don't make an 84" model in the Heritage series. I don't want to run any smaller than 7 ft.
Kerry
__________________
Old 11-02-2009, 03:17 AM   #24 (permalink)
PSDStu's Avatar
I run the Woods DS-96 3pt, Rotary Cutter on my M5040 and I think it's around 1400lbs. I've never had a problem using it. Lots of 8' cutters out there, Woods, Bush Hog, Landpride..etc..
You could also look at a 8' pull-type cutter.
Stu
Any opinions?
Kerry
__________________
08' M5040 w/Cab, Air Ride Seat, Radio/CD, DS96 Woods Rotary Cutter, Woods RM-990.
09' B3200, LA504 Loader, WR Long OBG2-48 Grapple, 5' Howse Rotary Cutter, 5' Box Blade, PRD-6000 RFM, Toothbar.
09' RTV 500.
____________________
PSDStu is offline   Reply With Quote
Old 11-02-2009, 08:46 AM   #25 (permalink)
Gold Member
Kerry
The HC72 is an 8' model with a 1" cutting capacity; won't cut heavy stuff.
Land Pride also has an RCR1872.
I wanted more cutting capacity, so went wirh the Woods DS1260.
Old 11-02-2009, 10:19 AM   #26 (permalink)
Stu
Thanks Stu... I was wanting to stick with a 3pt cutter and had almost pulled the trigger on an 8ft cutter that weighed about 1450. My concern would be warranty issues with Kubota if you had a 3pt problem under warranty and they learned that you had been using a larger width and heavier 3pt cutter than recommended. Yet there are many owner's using 3pt rotary cutters that exceed Kubota's maximum weight and width limit.
However in all fairness, I rarely have run a 3pt cutter with a solid top link. Just a chain....so the cutter is really no more than a drag type where the maximum weight limit is 11,000 lbs...
Kerry
__________________
Old 11-02-2009, 11:31 AM   #27 (permalink)
I'm glad you found what you wanted at a price you are happy with. I always say advice is worth what you pay for it. Everything on here is free, so its up to you to sort through all the posts you get in response and figure out what advice is good for your specific case.
I'm looking forward to some pics and enjoy the new tractor.
dodge man is offline   Reply With Quote
Old 11-03-2009, 01:13 AM   #28 (permalink)
PSDStu's Avatar
I understand your concern but a 7' cutter hanging so far back on the 3pt is in my view harder on the 3pt then the 8' cutter which sits closer to the tractor. Like you mentioned.... your not really caring that weight for very long before you set the cutter down and get to work. Go find the cutter you want and have some fun!
Stu
Kerry
__________________
09' RTV 500.
Old 11-03-2009, 07:06 PM   #29 (permalink)
While I agree (and had the same experience) of significantly different prices from different dealers, the Jan 2008 model vs. the 2009 model might have been different because Kubota raised prices and/or that the 2009 model was a -1 (turbo charged engine) whereas perhaps the 2008 was not.
The turbo only adds about 1 hp, but really is for meeting emissions requirements. I'd rather have a non turbo, less expensive things to go wrong.
Congratulations on your new toy...oops, I mean tool ;-)
Ken
M5040 with FEL
M9540 with 15' Bush Hog
(and a long list of other toys, mostly Kubota)
__________________
Retired with horses
Ken45101 is online now   Reply With Quote
Old 11-04-2009, 07:28 PM   #30 (permalink)
Ken
M5040 with FEL
The difference was definitely the result of higher dealer price in July 2009 vs Jan 2008. The difference was a little over $1730 in dealer cost. Both models were the non turbo M5040HD...not the M5040HD-1....which was a little surprising as I would have thought the July 2009 tractor would have been the later turbo. But it wasn't. I agree with you that the non turbo model was preferable. Had there been a difference of 5-10HP...then maybe, but my understanding was that the only reason the turbo was added on the -1 models was to meet Tier IV emissions.
The tractor was delivered as scheduled Monday afternoon and it's now parked in our shop building. Total hours is 3.1. I took a few pictures that I will post later tonight or tomorrow.
On Monday evening I had a coyote run out in front of the tractor as I was heading to the South end of our airstrip. He was only 50 yds away and would have been an easy shot...but I didn't have the rifle with me. ( I plan to install a vertical rifle mount just ahead of the 4WD lever). The crazy coyote looked mesmerized by the tractor. He obviously wanted to run...but was so curious he just stood there. I'm sure it was, without a doubt, the largest bright orange painted object he had ever seen. It was really pretty hilarious...
Kerry
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.28825 seconds with 8 queries
