Stubee
Looked at a B6200 today. SN 61433, geared, 4WD, unknown aftermarket loader (pistons say "Chief"), back blade, 6' plow jury-rigged for loader (!!). 219 hours showing but likely 1219 or who knows, new foamed rear tires. New hydraulic pump within past 3 years. Cosmetically pretty darned clean inside & out. Runs well all gears/PTO (didn't check 3 pt. lift), 4WD, clutch play good, no leaks, brakes good, no or little blow-by.
I can get it for $5K. Thinking not do it because 1) loader mounting/front of frame only & I can't decipher brand 2) loader frame is bent a bit so off-center to tractor (not the bucket, the frame) 3) loader won't hold up nor raise the tractor off the ground more than an inch, if that, when lowered 4) no coolant showing in radiator 5) radiator clean-out screen really clogged & owner didn't know it. A couple of other minor things like hydraulic coupling leaking all over my shoe--maybe why the loader is weak--& aged hoses, bad ignition switch but the loader is what's putting me off most.
Here are pics.
Here are pics.
