Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Super Member JOHNTHOMAS's Avatar
    Join Date
    Apr 2008
    Posts
    7,131
    Somerset, Ky
    L3901HST F3080 RTV1140 BX2370-1
    Default Discovered my Kubota F3080 has a horn!
    Mowed with my F3080 today in 90 degree heat. As I finished mowing and was on my way to my kubota Garage where I keep my BX25 and F3080 the horn started blowing on my F3080. I was surprised, I didn't know it had a horn. Problem was it wouldn't quit blowing. I looked at the dash to see if anything was lit up and noticed the heat gauge was near the red. Stopped and raised the top over the engine and pulled the screen out and the wind blew it clean, put it back in and left the ebgine cover up and run RPM at about low medium. Temp guage needle came down and horn stopped blowing. Wonder if there's a button that I can press if I want to blow it at a neighbor or deer or dog or some thing else? Now I wonder if other model Kubotas have the horn for heat? None of my other ten ever blew their horn. My F2680E did get over heated one time but no horn blew.
    2017 L3901 HST FEL, 2017 BX2370-1, 2012 F3080 4WD 72" RD, 2010/2009 RTV1140CPX , 72" Woods RFM, 60" LP Grapple, J DUNN Tree Grapple, 6' LP Rotary Mower, LP25 Hydraulic PHD, LP Quick hitch, RatchetRake , Rip and Dig, LP BB, LP 50" Tiller, Snow plow, Titan SSQA Forks, Titan Hitch Mounted Ripper, Titan SSQA to 3PH adapter plate, Sickle mower .. and Horse Drawn disk 13 Toyota Tacoma Double Cab, 17 Cadillac XT5. 2007 Toyota FJ Cruiser
  2. #2
    Platinum Member CBW1999's Avatar
    Join Date
    May 2008
    Posts
    857
    Northern Vermont on the 45th parallel
    Kubota 7510, Toro Groundsmaster 217D
    Default Re: Discovered my Kubota F3080 has a horn!
    Probably was a special edition, custom add-on done by Barlow's- since you are such a good customer.
    They know that you'll want to trade now, so all of your equipment has horns on them!
  3. #3
    Padawan Tractor Learner
    Advertiser
    Johndeere3720's Avatar
    Join Date
    Mar 2009
    Posts
    6,381
    NW Oregon
    Deere 317 & L118
    when i got my yanmar, i was happy to find a horn on it. I mostly honk at the dogs, they either move or if i push it a couple times, they think it means come so if they are barking at the neighbors dog, i can call them back with only the horn. They cant hear me yell at them with the purr of that diesel engine. There are a LOT of benefits of horns. They sure get peoples attention though. This last weekend i also cleaned out the air intakes and filters but didnt leave the hood open. Started er' up and there was only a cloud of dust. So i slowly gave it more throttle and got er' all blown out. I had to do this twice since it was so dusty mowing the fields and grading the driveway.
    Attached Thumbnails Attached Thumbnails Discovered my Kubota F3080 has a horn!-8-30-10-039-jpg
    My Fleet:
    2004 Deere 317 Skid Steer Loader
    66" Construction bucket, imatch QA adapter, Bobcat landplane ,4 in 1 bucket, Pallet forks
    2005 John Deere L118
    42" deck, bagger
  4. #4
    Super Member bp fick's Avatar
    Join Date
    Aug 2009
    Posts
    5,695
    Beaver Creek, Northern Michigan
    Kubota BX2360
    My Mercury outboards had them. Get into a patch of yucky weeds and such and have heard them go off. Pull up the outboard and clean off the tossed salad. Same principle.
    Good to know that kubota uses a similar thing.
    BP
    "Some chickens, some gardens and a Kubota."
  5. #5
    Veteran Member rjkobbeman's Avatar
    Join Date
    Apr 2010
    Posts
    1,002
    USA
    Kubota M8540HD-12 2010
    Quote Originally Posted by JOHNTHOMAS View Post
    I don't know if mine does. Hope I never find out!
    On a slightly related topic, my three year old is still not happy that my tractor does not have a horn! Of course, that does not prevent him from getting on it and doing what three year olds do!
    M8540HD12-1, R4s, Weights, 2 Remotes, Rear Lights, Down Exhaust
    LA1353 FEL, QA 72" Bucket, Self Leveling Valve, 3rd Function Remote
    CCM Category II Hydraulic Toplink
    QA 48" Pallet Forks
    M8180 Ballast Box with concrete
    LP QH-20 Quick Hitch
    LP RCR2672 6' Rotary Cutter
    LP GS2596 8' Grading Scraper
    BAC BG-10 Post/Tree Puller
    BX2370RV60-1, R4s, 60" Mower, Loader Valve
    BX2763A Snow Blade
    LP QH05 Quick Hitch
    Rear Remotes
    40 gallon 3ph sprayer
    Subsoiler with wire spool provision
  6. #6
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,800
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    My M8540 has a horn, but don't know about one for overheating.
    "In theory, there is no difference between theory and practice. But in practice, there is." - Yogi Berra
  7. #7
    Join Date
    Apr 2010
    Posts
    1,002
    USA
    Quote Originally Posted by TripleR View Post
    Really? That must be a CAB thing?
    QA 48" Pallet Forks
    BX2763A Snow Blade
    LP QH05 Quick Hitch
    Rear Remotes
  8. #8
    Join Date
    Mar 2009
    Posts
    18,800
    Missouri
    Quote Originally Posted by rjkobbeman View Post
    That could be. It is a button on the "dash".
  9. #9
    Join Date
    Aug 2008
    Posts
    130
    Western Kentucky
    B3030 G1900
    A lot of mechanics would not recommend running the engine with the hood up when it is hot as you are not getting the correct air flow, kinda by-passing the radiator with the hood raised.
    1992 G1900 60mmm 2500+ hrs., 2009 B3030 60mmm LA403 Fel/remote joystick 60 QA Bucket R3/Rimguard
  10. #10
    Gold Member davatk's Avatar
    Join Date
    Mar 2010
    Posts
    349
    Flint Hill, Virginia
    Kubota B2630
    John,
    Obviously that is the JT custom horn installation that Barlow installed to remind you that it is time to trade in one of your tractors.
Similar Threads
  1. JD5025 - Kubota 7040 - ?
    By threeman in forum Buying/Pricing/Comparisons
    Last Post: 09-02-2008, 07:59 AM
  2. Kubota will buy back my B3030
    By jgbiker in forum Kubota Owning/Operating
    Last Post: 10-27-2006, 10:39 PM
  3. Invisible Fence
    By bczoom in forum Related Topics
    Last Post: 03-03-2005, 09:58 AM
  4. Operating Opportunity - Kubota vs Kioti
    By rtimgray in forum Owning/Operating
    Last Post: 12-28-2004, 05:20 PM
  5. Kubota 2 Year Survey
    By rlk in forum Kubota Owning/Operating
    Last Post: 10-24-2003, 12:30 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
