CompactTractorFan
Super Member
It took a little while to get the BH & FEL off since it was the first time, but there were no major problems.
Thanks. Dimensions of each piece of wood? How long are they?
how sad- most of BX25'ers don't even have thier 3pt assembled yet. I use mine all the time. I'd say its the most handiest thing to have.
JT- I say just open the box and try to put it together. I don't think its that hard. I'd do it for you if you weren't so far away. :thumbsup:
JT, Hope these pics help!
1. Shows 3PH installed on BX25. Note parts in your box!
2. 3PH shown attached to back blade. Key is placement of large metal rod held in place after install by pin and cotter pin. When removed the part with the caution label {Grey} can be placed over the rod after the rod is in place.
3. Rod is held in place by two oblong shaped (note flat sides) inserted into side frame holes with a similar shape. Rod slides through center hole until {Grey} part covers the rod. Key installation step is putting rod in place as shown.
4. This shows view from above including right and left arm connection. Adjustment threaded rods are tightened as required for the attachment being used.
JT, Any questions? Need more pics? Good Luck! :thumbsup:
Thanks guys for the encouragement, info and pictures.I didn't do a triangle but made a simple 2'X4' plywood dolly with six heavy duty 4" swivel casters I got at Home Depot. The BH sat on the dolly lengthwise and was easy to roll around in the garage. It probably takes up more floor space than the triangle one, but was fine for my purposes.
I used 3/4 inch plywood and doubled the thickness so the whole thing was about 1.5 inches thick. Used construction adhesive and screws to glue the two layers together.
