What are cast wheels and radial tires, I hear people talking about them, but haven't been able to find out what the difference is.
Thanks!
Thanks!
Thanks!
Money. I think that when these guys are talking about cast wheels it is really only cast centers, (not wheel weights) but I may be wrong about that. I don't think that Kubota is going to offer radial R4 tires either, but again I may very well be wrong.
Something else to check on if you think that you may be interested.
Difference is the cast wheels basically have a wheel weight built right into the wheel so they're heavier and the cast centers are stronger where the axle/hub flange bolts attach to the wheels. Radials are better because generally they are a rounder, better quality tire and do not require a tube. :thumbsup:
The 7040 does have different dia AG's available. I got the tallest tires, but wish I had the cast center wheels. I'm no longer a fan of filled tires.
I was not aware that bias ply tires require a tube. I have 4 tractors (16 tires) and I believe that not one of them have a tube in them. :confused3:
I am a huge fan of filled tires, but would agree with you that a person that has to work in certain sometimes unknown conditions (as you do) probably should not have them.
To fill mine with rim gaurd, tubes were required.
