LA364 Loader Quick Coupler
   / LA364 Loader Quick Coupler #1
floydc
Kubota B2920
I have seen several owners show pictures of the QA Coupler on a LA364 Loader. The QA is made for the B3200 Tractor but they have it mounted to a B2620 Tractor. I have a B2920 Tractor and LA364 Loader and would like a QA coupler for a snow blade I am ordering. Kubota does not want to help on this issue. The do show three different model numbers and my dealer does not know which to order.
If anyone has a quick attach coupler mounter to a LA364 Loader I would like to know the model number of the coupler
Thanks - New Member.
   / LA364 Loader Quick Coupler #2
I'm not completely sure what you are asking for. You are looking for the Kubota proprietary coupler ? Or a universal skidsteer style? Is the plow you are looking at for the Kubota coupler?
I am looking for the Kubota proprietary coupler NOT the skid-steer style
I will try and load a picture.
   / LA364 Loader Quick Coupler #4
The Kubota Quick coupler is a B-1658 that will woork on a 364 loader.
Thank you so much, I have spent a lot of time trying to track this model number down.
   / LA364 Loader Quick Coupler #6
So, can you confirm that this fits the LA364, and how you went about modifying your system to work with it? I am very interested in doing this at some point, but my dealer said they could not confirm that the quick attach would work with the LA364 loader spacing or bucket.
   / LA364 Loader Quick Coupler #7
The 364 loader has the same arm spacing as the 504 loader used on the B3200. There is no problem putting Kubota's QA on the 364 loader.:thumbsup:
   / LA364 Loader Quick Coupler #8
so, how about the bucket? can you convert that to work with the QA adaptor just by getting a couple of extra pins?
   / LA364 Loader Quick Coupler #9
Just leave the top pins in the bucket. The lower pins come with the QA and you remove to come away from the bucket.
   / LA364 Loader Quick Coupler #10
I'm currently going through this with my dealer. I have a 2920, and he had a 3200 sitting on his lot. I measured the 3200 bucket and it's identical mounting to mine. He priced the coupler to me at $250, the pallet forks (Kubota) will be another $900 (forks and backplate/mast/whatever it's called).
