B2320 w/ LA504 Quick Attach And Kubota Forks
   / B2320 w/ LA504 Quick Attach And Kubota Forks #1
Northern 1
Central, NJ
Kubota B2320
Looking for input. Have bucket mount forks on our 2010 B2320 w/ LA304 and BH65. I'm not happy with bucket mount forks. Kubota does not list forks and quick attach for this loader, I'm told Kubota's official line is it is not available. It was recommended to me that the LA504 quick attach and forks will fit the loader. Anyone have experience with this setup or input? Quick attach between the bucket and forks is important, I'm not keen on pin-on style.
   / B2320 w/ LA504 Quick Attach And Kubota Forks #2
a member just got a B2920 with the B3200 quick attach and pallet forks, also a B2620, but the B2320 uses the LA304 loader not the LA364, but if the LA304 has the same width it should fit.
   / B2320 w/ LA504 Quick Attach And Kubota Forks #3
Yup that was me with the 2920 and the QA and forks from the 3200.
You need to measure the width of the pin attach points and the distance between the upper and lower pins from the 2320 and B3200 (or B2620/B2920) to see if they are the same.
I don't know if the B2320 connection is the same or not, I haven't seen a loader on one. Sorry.
Thanks for your thoughts.
   / B2320 w/ LA504 Quick Attach And Kubota Forks #5
id get a good welding shop to build a set of quick tach pallet forks for your loader.
   / B2320 w/ LA504 Quick Attach And Kubota Forks #6
I'm pretty sure that you won't have any trouble fitting the Kubota QH to your loader. I have that set up on my B2620, and it works OK. The pin holes don't line up as well as they should on mine so getting the forks on, and off usually takes a bit of "encouragement" that I haven't addressed yet. I don't think it is as nice, or quick to use as the JD arrangement, but it sure is faster than taking out all the pins manually each time. I would be really happy with mine if those bottom pins would slide in like they are supposed to.
Chuck - stamped on the cylinders for your loader are the bore and stroke. Could you let me know what they say. Thank you.
Check that out - thank you.
   / B2320 w/ LA504 Quick Attach And Kubota Forks #10
Chuck is your unit bent? I have the same set up and its real easy to get on and off although the JD may be a better QA design.
