Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Join Date
    Jan 2004
    Posts
    111
    Eastern, Pa.
    NH TC33D
    Default M59 vs L45 TLB
    Been looking at Deere 110 and now considering one of the above any comments. The 7-8000lb machine with rear PTO is what I am after. thanks
    TC33D, 7308 loader, 914 60in. mmm, acre-ease wing mowers, 7 ft rear blade, etc.
  2. #2
    Gold Member
    Join Date
    Feb 2005
    Posts
    460
    Southern NH
    M7040, L48, KX121-3, RTV 1100 and a couple of older Fords
    Default Re: M59 vs L45 TLB
    Go M59 or L48, the L45/39 is just to small compared to the others. The tires are tiny in comparison.
  3. #3
    Gold Member Stonehaller's Avatar
    Join Date
    Sep 2009
    Posts
    486
    Mid-Michigan
    Kubota L39
    Quote Originally Posted by curtisfarmer View Post
    Depends on what you are going to use the tractor for. I chose the L39 over the L48 because a wanted a smaller tractor for maneuverability in tight areas. I was originally looking for a JD110, but could not find a used one at reasonable cost that was not all beat to heck. I looked at the L48 but decided it was bigger than what I wanted. You do have less ground clearance with the L39 or L45 so that is a drawback. And of course, you have much more power with an L48 or L59. Other than tire size, the JD110 and L45 have essentially the same specifications.
    EDIT: Follow up on the JD110. Any hydraulic remotes, front or rear, are factory options only. So if you are looking at used tractors, make sure it has what you need. The three point hitch is an option, so again not every used tractor will have it. I think the hitch was about $800 from a JD dealer when I was looking a few years ago. Also, depending how and where you are going to use the tractor, there is a skid plate option for the JD110. It has a lot of hydraulic lines on the bottom and I saw a lot of damage to them on used tractors without the skid plates. My L39 has the hydraulic filters on the bottom and I made a guard for them after almost puncturing one. I am not sure about the L45 but I suspect the filter location is similar to the L39.
    Kubota L39TLB
  4. #4
    Silver Member ManAtArms's Avatar
    Join Date
    May 2009
    Posts
    217
    NJ
    2009 Kubota M59
    dirtball,
    the M59 is gonna weigh a bit over 8K...maybe 8300 with the hoe. Someone here should know the exact weight.
    -mark
    2009 Kubota M59, Hydraulic Thumb, front aux hydraulics,
    8' Ford 917 Flail Mower
    Belltec H-300 auger, Markham Grapple, Bradco forks
    Landpride GS-1560 Grading Scraper
    2008 ASV PT50
    Other Toys
    Built-Rite 24 HPWS-D splitter
    Dolmar PS-5100s
    Stihl MS-441
    Makita DCS-6401..upgraded to 79cc
    a pit bull or two (RIP Tugboat)
  5. #5
    Join Date
    Jun 2005
    Posts
    192
    Western Ma
    Kubota M59, B3030, B7100
    L45TL 5350lb
    L45TLB 7275lb
    M59TL 6158 lb
    M59TLB 8345 - 8455 depending on options
    weights from 2010 whole goods doc.
  6. #6
    New Member
    Join Date
    Mar 2011
    Posts
    21
    Kubota L45
    I just bought an L45, couldn't be happier. Wanted the beefiest tractor I could tow w/ my 2500 HD so it came down to the L45 and the 110. Would have liked the M59 but too heavy to haul w/ my pick-up not to mention 10K+ more.
  7. #7
    Join Date
    Sep 2010
    Posts
    688
    Eastern Ontario
    Kubota MX5100
    Comparing the Deere 110 to the L45 is the correct one. The M59 is a lot beefier. I like the L45 because of it's size/weight. Both are very nice machines. I haven't test driven the 110 as there are no close Deere dealers but the L45 is very nice to drive and that BH --> .
    2011 Kubota MX5100, BH92, BH BB72, Walco Bush Hog and Snowblower, Wallenstein 310 Splitter & Forks
  8. #8
    Super Member
    Join Date
    Apr 2000
    Posts
    6,579
    central New York
    all makes and models
    Had a customer swap up, his thoughts, why didn't you sell me that the first time!!!! I did offer it to him but he said he didn't see where it was worth the extra money to him.
    That was until I sold one to a freind of his and he had a chance to operate his!! Took less then 48 hours from the time of operating to complete the sale.
  9. #9
    Join Date
    Jan 2004
    Posts
    111
    Eastern, Pa.
    NH TC33D
    Questions- can you drop the loader on both machines ? Why no cab on the M59? If that unit had AC/Heat I'd have all my prayers answered in regards to the perfect sized tractor for most of my weather challenged tasks. Snow removal, brush hogging. Where is most of the weight in the L45 compared to the lighter L's ?
  10. #10
    Join Date
    Sep 2010
    Posts
    688
    Eastern Ontario
    Kubota MX5100
    Quote Originally Posted by Dirtball View Post
    I know the bucket is QA, not sure about the loader 'arm's themselves. No idea about the cab on the M59 and why they didn't but I now kubota has never had one for their TLB lineup. The weight of the L45 vs other lighter L's I believe is in the frame - much beefier/heavier grade steel. You can easily see the difference if you compare it with another Kubota on a lot. The BH definitely adds some weight as well of course.
Similar Threads
  1. Tractor Purchase Recommendation - Mahindra vs Kubota vs New Holland vs JD
    By jascott in forum Buying/Pricing/Comparisons
    Last Post: 10-10-2015, 10:31 PM
  2. Price Check Kubota TLB M59
    By crudolph in forum Kubota Buying/Pricing
    Last Post: 06-18-2011, 06:01 PM
  3. John Deere 3032e vs New Holland t1510 for 60acres
    By Radiater in forum Buying/Pricing/Comparisons
    Last Post: 05-06-2011, 04:25 PM
  4. 5 years ago today
    By Tdog in forum Related Topics
    Last Post: 08-31-2010, 11:08 AM
  5. Jd 110 or M59 TLB
    By Kytractor in forum John Deere Buying/Pricing
    Last Post: 04-26-2008, 07:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
