Results 1 to 10 of 13
10-15-2011, 01:10 PM #1Veteran Member
- Join Date
- Dec 2007
- Posts
- 2,424
- Location
- texas
- Tractor
- MX5100 HST W/844 FEL
grand L 4240
went to a big equipment auction in okla yesterday.they had a like new grand l 4240 4x4 w/fel with less than 300hrs on it,w/ROPS an sun shade.an it ended up selling for $16,600.was a nice looking lil tractor,but man the way it was designed would run me bonkers.most everything was in a akward pos for me.it had a push button on the floor insted of the rocker pedal.the loader didnt have the joystick on it.
10-15-2011, 02:17 PM #2Veteran Member
- Join Date
- Feb 2009
- Posts
- 1,476
- Location
- north of upstate ny
- Tractor
- Kubota L4240 HST Cab
Re: grand L 4240
Boy don't know about that one;my L4240 has a rocker for the HST,how do you run a loader with-out a joy stick?May-be had been set up for handicapped operator?
10-15-2011, 02:28 PM #3Super Star Member
- Join Date
- Mar 2009
- Posts
- 13,656
- Location
- Missouri
- Tractor
- Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
Re: grand L 4240
That is why it is so important for people to try tractors out before buying them and spend as much time on them as possible to acclimate. I really liked the controls on the L4240 especially the HST pedal. We didn't buy one because an excellent deal came up on a lightly used L5030, but we were going to order one after crawling on and off different tractors for quite some time.
10-15-2011, 04:59 PM #4Veteran Member
- Join Date
- Dec 2007
- Posts
- 2,424
- Location
- texas
- Tractor
10-15-2011, 05:12 PM #5Super Star Member
- Join Date
- Mar 2009
- Posts
- 13,656
- Location
- Missouri
- Tractor
Re: grand L 4240
I checked the Kubota website and pulled up a picture and it is not to dissimilar to my L5030, but looks even easier to use. I like the joystick close to me and prefer the joystick on the GL to the one on the M8540.
Since the L4240 is offered in a cab unlike the MX5100, the joystick cannot be loader mounted.
One good reason to try them all out.
10-15-2011, 08:21 PM #6Veteran Member
- Join Date
- Dec 2007
- Posts
- 2,424
- Location
- texas
- Tractor
Re: grand L 4240
i guess im strange i like the joystick mounted to the loader thus making it easy to use for me.i would get messed up if it was on the right side by the seat.
10-15-2011, 09:15 PM #7Platinum Member
- Join Date
- Sep 2009
- Posts
- 986
- Location
- Indianapolis
- Tractor
- Kubota L3940 Ford 8N Ford 6000
Re: grand L 4240
The GrandL has the loader stick mounted on the tractor. That way you can remove loader, add sub-frame, and operate front blade, rotary broom, or snow blower with FEL control lever. This is becoming more popular on this size of tractor due to their ability to multi-task. Philip.
Kubota L3940HST-1 2009
84" front blade
LA724 loader w/quick attach
HD 72" round back bucket
turf tires
Ford 8N 1950
Ford 6000 diesel 1961
JD LX188 1997
JD L110 2003
Woods RD7200 finish mower, Bearcat CH5540 5" chipper, L8170 ballast box, 6' Woods pulverizer, 6' Dragon box scrapper with hydraulic rippers, 14" 2 bottom plow, sub-soiler, post hole auger, 3 point pallet forks, 3 point 2" drawbar receiver, 30" rear scoop, 7' Land Pride RB1584 rear blade, 3 point boom pole
10-15-2011, 10:56 PM #8
Re: grand L 4240
My case (even though it is a cabbed tractor) has the loader control mounted on the dash while my 4240 is next to the seat. I find I can use the 4240 easier at night because it's 'right there' while the Case I have to reach for. Also there's just enough room to exit the tractor on the right side if required. Any further forward and I think it would make it impossible. But everyone is different.
Kubota L4240,Case 580K backhoe, Case 450 Dozer
10-16-2011, 09:17 AM #9
10-17-2011, 10:50 AM #10Silver Member
- Join Date
- Oct 2010
- Posts
- 215
- Location
- NYS--Various Parts
- Tractor
- Airens/Simplicity/Sears
Re: grand L 4240
A question on this issue, but first, a caveat:
I'm assuming the fender-mounted and loader-mounted sticks on the Grand L's and the B2630's are physically the same units, dimension-wise, etc.... If anyone knows otherwise, please comment, so I'm not trying to compare apples to oranges here. Thanks.
I tried a BX25 and a B2630, both with Loader-mounted FEL sticks. My father is 86 years old, and owned and operated dirt equipment (977's, D-5's? etc...) for many years before going to all hydraulic cranes, for 20 years. His largest crane was a 55 tonner.
He said his friend's Grand L (5740? 4750? Neither of us can remember--he said it had the cab and the whole shebang, costing in excess of $50K) has the fender-mounted joystick.
My Dad said that he found that WITH IT'S SHORTER LENGTH, the Grand L's fender-mounted stick is actually HARDER TO DUMP AND CURL ACCURATELY, when doing fine work (I'm imagining loading equipment, etc...--not simply moving dirt).
He explained that the longer stick on the loader-mounted models actually gives you MORE CONTROL, due to the larger movements required. (I think his comment only applies to longer, loader-mounted sticks on FEL's generally--I don't think he's operated a loader-mounted stick on a Kubota--just the fender-mounted one, on the Grand L, above),
Anyway, again, he found the dump circuit on the fender-mounted control would "dump awful quick, if you're not careful, as it's a little harder to control, with it's shorter stroke."
He STILL works, sometimes, as it suits him, in the crane business, as he likes it, but he has used this Grand L a lot, recently. He spoke very highly of it, otherwise, and said the owner overworks it mercilessly, and yet "nothin' broke."
I just wondered if anyone else could comment on this issue, as I want to possibly order a B2630 with the fender-mounted (short stick).
My concern is, much of my work will be more "precision work" (loading/unloading with SSQA forks) and I am concerned about the dump circuit being too hard to exert consistent fine-motor-control over, if my father's experience is generally true of the Kubota fender-mounted joysticks.
Btw, my Dad is a WWII combat veteran (motor pool sergeant who was running dozers, cranes, etc...in the Philippines, when he wasn't being shot at or bombed--they lost almost half their unit when the ammo dump was blown up--may they R.I.P.), so he's been in construction for 67+ YEARS, still runs cranes, and takes a motor home KISS would tour in, across the country, to truck shows, so he's still an expert operator, bless his soul, not to mention the gentlest "gentleman" I've ever known, despite a lifetime in the construction business. (Please knock on REAL wood for him, three times--I'm superstitious--thanks!).
So I was going to take his advice, and get the B2630's standard, LOADER-mounted FEL lever, but a recent back injury (and surgery) has me wondering if I really want to LEAN FORWARD to operate the FEL.
Does the LOADER-MOUNTED "LONG-stick" REQUIRE one to lean forward, on the B2630? I can't remember if I actually HAD to lean forward to use the loader-mounted FEL lever I tested out last year, before I was injured, as I was not conscious of this potential issue back then. I'm hoping it won't be an issue now, but I'm thinking I should play it safe and get the fender-mounted stick, just in case. But if it IS too sensitive to control accurately, for fork-work (loading my truck, installing/removing my 300+lb. pick up cap, etc...) then the fender-mounted stick could cause more problems than it's worth, potentially.
And the only fender-mounted sticks I've used were 20+ years ago, on his 480 and 580K Case backhoes.
I'm assuming physical size has something to do with it, so I'll tell you that I'm 5'10-ish and height/wt. proportionate--other than the Heineken baby I'm carrying.
Thanks,
My HoeLast edited by My Hoe; 10-17-2011 at 11:26 AM.
Similar Threads
Price Check Is this 4240 a good deal?
By tpetty in forum Kubota Buying/PricingReplies: 10Last Post: 09-10-2011, 09:54 PM -
Trading up to a 4240
By Johnbro in forum Kubota Buying/PricingReplies: 15Last Post: 11-30-2010, 05:31 PM -
Kubota 4240 non turbo v JD 3720 turbo at hi alt
By jaj2 in forum Owning/OperatingReplies: 7Last Post: 04-21-2010, 11:48 AM -
Will a 4240 Cab reliably handle all of this?
By Lt CHEG in forum Kubota Buying/PricingReplies: 7Last Post: 10-29-2009, 12:24 PM -
Crossthreaded ?? HST Trans filter 4240
By JFD3940 in forum Kubota Owning/OperatingReplies: 7Last Post: 05-16-2009, 07:41 PM
