Results 1 to 10 of 10
  1. #1
    Super Member Robert_in_NY's Avatar
    Join Date
    Aug 2001
    Posts
    8,213
    Silver Creek, NY
    Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
    Default What does the F stand for in the M5040F
    I am curious as to if this is suppose to be a fruit tractor for use in orchards and such. I went to Kubota.com but can't find anything about this model. I am curious as to the narrowest width the tractor can narrow down to. I am always looking for decent used tractors to use in the vineyard and until recently have not paid much attention to Kubota.
    2008 KUBOTA M5040F 40 HP to 99 HP For Sale At TractorHouse.com&
    God must love stupid people; He made so many
  2. #2
    Join Date
    Apr 2010
    Posts
    63
    TN
    Default Re: What does the F stand for in the M5040F
    F is 2wd.
  3. #3
    Super Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    7,751
    Branson, Mo.
    Kioti DK35se Hydrostat
    Yep, all F are 2wd
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
  4. #4
    Join Date
    Aug 2001
    Posts
    8,213
    Silver Creek, NY
    Default
    Thanks guys
  5. #5
    Veteran Member houstonscott's Avatar
    Join Date
    Dec 2010
    Posts
    1,618
    Oglesby, Texas
    Kubota RTV 1100
    Fruit
    HS
  6. #6
    Veteran Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    2,030
    texas
    kubota M7040 &m7040
    Fantastic
  7. #7
    Join Date
    Jun 2009
    Posts
    7,751
    Branson, Mo.
    Kubota uses these designations to identify the differences and variants of each line:
    BX Series
    V = Loader Valve
    T = Turf Tires
    R = R4 Industrial Tires
    LB-T = Loader Backhoe w/Turf Tires
    LB-R = Loader Backhoe w/R4 Tires
    B Series
    E = Two Wheel Drive DT = Dual Traction 4wd
    HSE = Hydrostatic Transmission, 2wd
    HSD or HSD-1 = Hydrostatic Transmission, 4wd
    HSDB = Same as Hydrostatic 4wd, but includes Bi-Speed turn
    HSD-T = Hydrostatic Transmission, 4wd, Tow Tractor (Airlines)
    TL = Tractor, Loader
    TLB = Tractor, Loader, Backhoe
    L Series
    DTC = Dual Traction, 4wd, Two stage clutch, Live continuous Running PTO (L235/L275) DTC = Dual Traction, 4wd, Integral Factory Cab (L3600/L4200) DTN
    DTS = Dual Traction, 4wd, Power Steering
    DTSC = Dual Traction, 4wd, Power Steering, Two stage clutch, Live continuous Running PTO (L235/L275)
    DTN = Dual Traction 4wd, Narrow Specialty Tractor DT-W = Dual Traction 4wd, (W) Wet Clutch = EVER CLUTCH
    F = Two Wheel Drive
    FS = 2wd, Power Steering
    FC = 2wd, Live-continuous running PTO
    FSC = 2wd, Live-continuous running PTO, Power Steering
    FST = Fully Synchronized (Main) Transmission
    GST = Glide Shift Transmission
    GSTCA = Glide Shift Transmission, 4wd, Factory Cab, "A is for Air Ventilation Kit (L3600/L4200)
    GSTC = Glide Shift Transmission with Integrated Factory Cab
    HC = High Clearance (L245HC only)
    HF = Hydraulic Shuttle, 2wd
    HDT-W = Hydraulic Shuttle, Dual Traction 4wd, (W) Wet Clutch = EVER CLUTCH HDT = Hydraulic Shuttle, Dual traction
    HSTC = Hydrostatic "Feather Step Transmission with Integrated Factory Cab MF = Mechanical Shuttle, 2wd
    MDT = Mechanical Shuttle, Dual Traction
    SS = Shuttle Shift
    T = Tow Tractor
    W = Wide tread for Row Crop applications. (i.e., Tobacco)
    DTC = Dual Traction 4wd, Cab Model
    DTCCS = Dual Traction 4wd, Cab with Creep Speed
    M Series
    DT-1 = Dual Traction 4wd, ROPS model with IC/Shuttle Transmission (M7580/M9580)
    DTL = Dual Traction 4wd, Low Profile (for orchards)
    DTM = Dual Traction 4wd, MUDDER (for specialty, row crop and vegetable)
    DTN = Dual Traction 4wd, Narrow (for vineyard/orchard tractor)
    DTN-B = Dual Traction 4wd, Narrow wheel tread with Bi-Speed Turn
    F = Two Wheel Drive
    F-1 = (-1) = Larger two pump hydraulic system
    FC = Two Wheel Drive Cab Model
    F-CS = Two wheel drive with Creep Speed (Ag. tires or as Turf Special)
    HC = High Clearance (2wd M7950 only)
    HD = Hydraulic Shuttle, 4wd
    HDC = Hydraulic Shuttle, 4wd, Cab
    HDCCS = Hydraulic Shuttle, 4wd, Cab, Creep Speed
    L = Low Profile
    ML = Mechanical shuttle, Low profile
    MDT = Mechanical shuttle, Dual traction 4wd
    MDTL = Mechanical shuttle, Dual traction 4wd, Low profile
    MF = Mechanical shuttle, Two wheel drive
    OC = Orchard model
    S = Synchro-Shuttle, 2wd
    SD = Synchro-shuttle, 4wd
    SCS = Synchro-Shuttle, 2wd, Creep Speed
    SDN-B = Synchro-Shuttle, 4wd, Narrow with Bi-Speed Turn
    SDNBC = Synchro-Shuttle, 4wd, Narrow with Bi-Speed turn, Cab model
    SDNBF = Synchro-Shuttle, 4wd Narrow with Bi-Speed turn, Foldable mid-mounted ROPS
    SU = Special Utility, 2wd
    SU-R = Special Utility 2wd, Rigid ROPS
    SU-F = Special Utility 2wd, Foldable ROPS SU-TF = Special Utility 2wd, Turf Special
    SUD-R = Special Utility, 4wd, Rigid ROPS
    SUD-F = Special Utility, 4wd, Foldable ROPS
    SUMDT = Special Utility, Mechanical Shuttle, 4wd
    SUDT = Special Utility, 4wd
    W = Wide Row
    H = 2WD, ROPS (Note: All H-Models are Std. Swing Shift 16F X 16R speeds)
    HC = 2WD, CAB
    HD = Swing Shift, 4WD, ROPS
    HDC = Swing Shift, 4WD, CAB
    DS = Dual speed, ROPS (Note: All Dual Speed models are 32F X 32R speeds)
    DSC = Dual speed, CAB
    SDSCC = Dual speed, CAB, cold weather w/high amp alternator and creep speed and second remote valve
    SDSC = Swing Shift Dual Speed, CAB DSDF = Dual Speed, 4WD, ROPS
    SDSL = Dual Speed, 4WD, Low Profile
    M-Series Notes:
    Suffix "1 models are the second generation "Wide Cab tractors. Cab is 5.7 inches wider than first models.
    Suffix "2 models are factory equipped with 540 / 1000 RPM PTO kits. M95S and M105S:
    The "S represents the model/tractor class in general is no specific meaning, however it can be applied to "Swing Shift as the base transmission on all "S models.
    M50-Series 1983 - 1984 Cab was orange in color, air conditioning was optional.
  8. #8
    Elite Member
    Parts Supplier
    MessickFarmEqu's Avatar
    Join Date
    Feb 2004
    Posts
    4,623
    Lancaster County, PA
    .. not that it really matters, but there are several of those that are wrong.
  9. #9
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    13,685
    Missouri
    Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
    Quote Originally Posted by MessickFarmEqu View Post
    Do you have a correct listing you can post? Thanks
  10. #10
    Join Date
    Aug 2001
    Posts
    8,213
    Silver Creek, NY
    Neil, if you guys get any used vineyard tractors in there can you think of me and let me know. I'm still looking for an open station narrow tractor that I can mount the post pounder on. I doubt I can justify another new tractor anytime soon but I am still thinking of a L4400 but if I can find a decent vineyard tractor used that would be ideal. There was a JD 5425N open station tractor with 600 hours on it that just sold for $8750 at an auction this month that would have been ideal but we still hadn't closed on the new farm so I couldn't buy it then have the deal fall through.
    So anything with Orange or Green paint on it would work well for me.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
