Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Gold Member
    Join Date
    Nov 2009
    Posts
    338
    Grimes County, Texas
    Kubota GL 3940
    Default Moving up - L3240 or L3940
    Hi All,
    Been a while since I've posted but now once again would like opinions and experiences to help with a decision on which model to go with. At the moment I have a BX2660 with attachments (as per my sig line) which was exactly the right tractor for the need to work my original 4 acres around the house. I've since purchased another 10 acres and have decided a tractor upgrade would make my life easier as the BX just doesn't have the capacity for me to maintain 14 acres efficiently. It'll get most of the jobs done but I'd like to cut some time off of most of the work.
    The new tractor would be used mainly to bush hog, move brush and downed trees, landscaping, etc.
    The implements I'm looking to add would be FEL with quick attach bucket, qa grapple, 5 or 6 foot shredder, possibly a box blade.
    So to the questions:
    1. I'm leaning toward the smaller 3240 as I've been amazed at what the bx can do with the horspower it's got. It's taught me that max horsepower, while nice, may not be required. This would save me some money that could be put towards the implements. I've seen other threads where the concensous was to get the heavy FEL and loader. Would the smaller tractor have any problems using this set up to it's fullest capacity?
    2. What's the practical difference between the round back and square back buckets?
    3. Are there any "issues" with either of these tractors I should be aware of going in?
      1. Shredder size 5' or 6'?
    4. This one is probably the most subjective but do you think these tractor choices are a good fit for my purposes?
    Thanks in advance for any input you guys can give.
    Kubota GL 3940, FEL w/ssqa, third function valve, grapple, 6' Landpride cutter, 6' landscape rake, 6' box blade, post hole auger
    "Knowledge is knowing the street is one way. Wisdom is still looking both ways before crossing"
  2. #2
    Elite Member nybirdman's Avatar
    Join Date
    Feb 2009
    Posts
    3,817
    north of upstate ny
    Kubota L4240 HSTC,L3000DT
    Default Re: Moving up - L3240 or L3940
    I had a L3130(replaced by the L3240),very nice all a round tractor;they are a 3cylinder diesel.The L3940 is a four cylinder and larger framed tractor,but the sweet spot in the lineup IMHO.In between the L3540(same frame as L3240 and a three cylinder).I purchased a L4240 for the larger 854 loader.If you are not going to add a back-hoe..the L3240 will do everything you need.Stick with the five ft.shedder,I don't know the difference in price on the buckets but would recommend the HD round-back and the larger loader.Have the rear tires filled.
  3. #3
    Gold Member
    Join Date
    Nov 2009
    Posts
    338
    Kubota GL 3940
    Thanks birdman,
    Good thought on filling the rear tires. I'll do it. Does the round back bucket have more capacity than the square back? Would the 72" bucket be a good fit for the tractor or would the 66" be more appropriate? Can anyone tell me what the 4in1 bucket refers to?
  4. #4
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    2,276
    Canada
    B3200, L5740,
    Well I always believe that the best route is to buy the max HP in the size of tractor you like. I also think that it is poor economy to not get the toughest loader you can get too. A little ballast and you will be amazed how much more capable the bigger loader is.
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    ZD1211
    GF1800 sold
    Kubota RTV900
    JD 850D Gator sold
    JD F935 x 2 sold
    Case 590SM-2
    JD 310D TLB sold
    Ford 555D sold
    Gehl 602 excavator sold
    JD317 sold
    JD323D
  5. #5
    Gold Member
    Join Date
    Nov 2009
    Posts
    338
    Kubota GL 3940
    Quote Originally Posted by kuboman View Post
    My general thoughts as well. I don't think I would regret going with the bigger tractor but trying to balance need and budget makes me lean towards the 3240. That 3940 sure is a fine tractor though!
  6. #6
    Gold Member
    Join Date
    Nov 2009
    Posts
    338
    Kubota GL 3940
    As a thought, any reason other than size of cut I couldn't keep my 48" shredder and used it behind one of these tractors. Maybe try it out for a while and see if it works for me. Lots of trees to mow around and maybe the smaller shredder would have an advantage?
  7. #7
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,799
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Quote Originally Posted by RTII View Post
    Sure, you can do it, but I have a 48" cutter for my BX2660 and there is no way I would use it on anything above a B Series.
    "In theory, there is no difference between theory and practice. But in practice, there is." - Yogi Berra
  8. #8
    Gold Member
    Join Date
    Nov 2009
    Posts
    338
    Kubota GL 3940
    Quote Originally Posted by TripleR View Post
    Because.....??
  9. #9
    Join Date
    Mar 2009
    Posts
    18,799
    Missouri
    Because.....??
    Because I would bend the snot out of it.
    I see no reason to get a bigger tractor to run the same size equipment, but that's just me.
    I run a 4' on our BX, 6' on the 5030 and 10' on the 8540.
  10. #10
    Join Date
    Feb 2009
    Posts
    3,817
    north of upstate ny
    I used a five ft.shedder on my L3130 and it was a good fit,also use it on my L4240..I could use a six ft. but until this one breaks beyond repair I will continue to use it.The four won't cover your tracks (with a L3240) but would be useable I would think.
    I never used a 4n1 bucket but it would require a third function on the front to work.They can open to grasp/scrape ect.A grapple or a thumb on the bucket would also require a third function.For my use I added a thumb to my bucket and a tooth-bar,works for me.
Similar Threads
  1. Grapple Looking for a good grapple bucket suggestion for a Kubota L3940.
    By pepper98 in forum Attachments
    Last Post: 09-24-2011, 07:57 PM
  2. Tractor Sizing L3240 Cab vs L5240 Cab Size Question.
    By PSDStu in forum Kubota Buying/Pricing
    Last Post: 02-29-2008, 08:25 PM
  3. Price Check L3240 or L3940 (pricing)
    By 1586 in forum Kubota Buying/Pricing
    Last Post: 01-18-2008, 06:52 PM
  4. L3940 and L4240
    By jwalk2c in forum Kubota Buying/Pricing
    Last Post: 09-06-2007, 01:54 AM
  5. L3240 or L3940?
    By TNvol in forum Kubota Buying/Pricing
    Last Post: 04-05-2007, 04:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
