Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Apr 2012
    Posts
    640
    pa
    kubota 7040sud
    Default kubota 5100mx
    IS the Kubota 5100mx based on an L series frame or is it based on an M SERIES FRAME THE DEALER TOLD ME TRACTORS A MIXES ON BOTH THE M AND THE L SERIES BUT HE DIDNT TELL ME IT THE FRAMES AN L SERIES FRAME OR AN M SERIES FRAME I WAS THINKING IT HAS AN L SERIES FRAME I COULD BE WRONG
  2. #2
    Join Date
    Jan 2012
    Posts
    960
    Success Missouri
    Kubota L3800DT, L3750
    Default Re: kubota 5100mx
    Here we go again...
    Closer to a Grand L, than a Basic L... Look at the weight specs.
    MX series is on MX chassis...
    Don
    Kubota L3750 Hydro Shuttle, 4wd, FEL; L3800 Gear drive, 4wd, FEL
    Huskvarna XP chainsaws 346xp X2, 357xp, 562xp, 359, 365xpw75cc
  3. #3
    Join Date
    Apr 2012
    Posts
    640
    pa
    kubota 7040sud
    BLUEGILL2 WATEVER I GOT THOUSAND OF HRS ON A TRACTOR CAT 943B CASE 580B
  4. #4
    Join Date
    Jan 2012
    Posts
    960
    Success Missouri
    My comment was based on all your other threads that appeared to be train wrecks.
    Anyway, look at the weight specs. The MX5100 is 1100 lbs heavier than a L3800.
    Also, the L4600 is built on a Grand L chassis...
    The L2800, 3200, 3400, 3800 are basic L series.
    Don
  5. #5
    Veteran Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    1,382
    Central MA, Lakes Region NH
    Kubota L4610 and John Deere 410
    Default
    It's basically the same as my L4610 if I remember correctly. No more lift capacity both front and rear. I haven't compared measurements but it's a lot closer to an L and much less capable than a true M.
    Kubota L4610 and John Deere 410 - WR Long 64" Grapple (best attachment ever!) QA front forks, rear forks, Brown 472 HD Rotary Mower, homemade 3 pt log splitter, Land Pride rake/blade combo, Land Pride HRL 3578 box blade (Hydro scarifiers), Shaver SC50 3 pt. Stumpgrinder, FitRiteHydraulics TnT, 6" Vermeer PTO Chipper (Hydro feed), 2 bottom Disc Plow, Ratchet Rake
    Rear Remotes Install
    How to search TBN
  6. #6
    Gold Member BleedGreen's Avatar
    Join Date
    Nov 2006
    Posts
    471
    Iowa
    John Deere LX178
    kubota 5100mx-5e-vs-mx-1.jpgkubota 5100mx-5e-vs-mx-2.jpgkubota 5100mx-5e-vs-mx-3.jpgkubota 5100mx-5e-vs-mx-4.jpgkubota 5100mx-5e-vs-mx-5.jpgThe MX is definitely not built on the M frame - whether it is on an L or a Grand L I dont know, but from the specs it looks like it is the Grand L. Attached are some photos of the MX5100 and John deere 5055E which is assuredly a true Utility Tractor.
    I can run a D100 and a 9560RT (and most of the models in between) all in the same day!!!
  7. #7
    Join Date
    Jan 2012
    Posts
    960
    Success Missouri
    Quote Originally Posted by BleedGreen View Post
    What's the price difference???
    The JD is much larger, but I like the looks of it! Some will find the compactness of the Kubota in that size range more useful, others not so much...
    Don
  8. #8
    Join Date
    Nov 2011
    Posts
    586
    Southwestern Virginia
    JD 5055E
    Case245, have you looked at that deere. It was bigger than I needed, but a nice tractor. The price was reasonable, if I remember correctly.
    Bill
  9. #9
    Gold Member OrangeToys's Avatar
    Join Date
    Nov 2011
    Posts
    269
    Missouri
    2011 Kubota MX5100
    I looked at the JD 5055E and the biggest reason I went with the Kubota was the price and the Hydro, I do more loader work than I do PTO. I wish I had the wieght and loader capacity of the JD though
    I like to push buttons that I dont know what they do to find out. Theres some I wont push anymore
  10. #10
    Join Date
    Nov 2011
    Posts
    586
    JD 5055E
    Case245 any luck selling your Kubota?
Similar Threads
  1. 2006 Kubota B3030 4WD HST & Kubota 5' mid mount mower
    By bmw2aprilia in forum Private Party Ads
    Last Post: 03-10-2012, 03:10 PM
  2. Replies: 0
    Last Post: 08-13-2011, 07:38 PM
  3. Kubota M4900 MFWD with Kubota LA1002 Loader, Low Hours
    By Jeff Quinn in forum Private Party Ads
    Last Post: 07-02-2011, 10:05 PM
  4. Replies: 1
    Last Post: 11-17-2009, 01:27 AM
  5. Kubota L4400, Kubota M5040 or Kubota 3240 ? Need input!
    By lemonshark2008 in forum Kubota Buying/Pricing
    Last Post: 11-14-2008, 09:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
