Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Silver Member beckmurph's Avatar
    Join Date
    Jul 2005
    Posts
    187
    Home/Catlettsburg Farm/Robinson Creek, Ky
    Kubota B3200TLB BX25(sold) b2620TLB(sold)
    Default Unintended consequenses
    On a B3200: If you should decide you want to upgrade the dynamo to an alternator, then that will create a little problem.
    I recieved the new B3200 week before last and as I was looking over it for the first time I was checking the oil in the engine. Looked and looked and could not find the dipstick. Finally found it right beside the new upgraded alternator. That was good. But then I tried to remove the dipstick. I could not get my hand on the dipstick. It is beside the alternator and below the muffler. I finally got the dipstick out from the opposite side of the tractor, but then, I could not get it back in. I had to take the side panel off to put it back . That alternator takes up a lot of space.
    Unintended consequenses-2012-08-30_16-08-15_238.jpgUnintended consequenses-2012-08-30_16-08-00_382.jpgUnintended consequenses-2012-08-30_13-36-49_376.jpg
    2012 B3200TLB Woods RB72 Rear Blade Woods RFM60 Finish Mower Woods RCR48 Rotary Cutter
  2. #2
    Elite Member JOHNTHOMAS's Avatar
    Join Date
    Apr 2008
    Posts
    4,777
    Somerset, Ky
    currently own F3080 F3080 B2620 FEL/BH RTV1140
    Default Re: Unintended consequenses
    Quote Originally Posted by beckmurph View Post
    Click image for larger version.
ID:	279569Click image for larger version.
ID:	279568Click image for larger version.
    You think you've always got to be "messing" with stuff. Now you've checked it, leave it alone until you do an oil change service when you'll probably remove those panels anyway. You know these Kubotas don't burn oil, it'll be OK till change time.
    Good looking tractor and is that picture going to be titled "Woman on the Rocks with Kubota"? If that's you, get off your butt and start working. Good looking property to.
    2012 B2620 FEL BH, 2010 F3080 4WD 72" Rear Discharge Deck, 2012 F3080 4WD 72" side discharge deck, 2010/2009 RTV1140CPX , RatchetRake, Forks, ...DEARBORN 2 BOTTOM PLOW 12" ?? FOR SALE $425).... Drawbar and Horse Drawn disk 11 Dodge Ram1500, 13 Ford Flex. 2009 Subaru Impreza Sport
  3. #3
    Join Date
    Jul 2005
    Posts
    187
    No JOHNTHOMAS that is not me. That is my lovely bride of 42 years. And thank you for the complements. By the way, that rock she is sitting on was picked up by the b3200 and put in place at idle. That rock is the same one that is in the bucket of my ex b2620 in my avatar. And it could only get it off the ground enough to move it.
  4. #4
    Join Date
    Apr 2008
    Posts
    4,777
    Somerset, Ky
    I'm noticing my new B2620 seems to have more power in the hydraulics than the weight of the body of the tractor can handle. I've used the BH a couple of times and the body keeps wanting to slide around as the bucket digs. Didn't have a BH on my B3200 but it was carrying more weight and seemed more able to deal with the power..
    42 years???? I guess she's decided to keep you and not throw you back if she's kept you that long.
  5. #5
    Join Date
    Jul 2005
    Posts
    187
    I found that with the b2620 I had to raise the front off the ground
    with the fei. That made things more stable
    Yea, she is stuck with me
  6. #6
    New Member
    Join Date
    May 2012
    Posts
    22
    Cashmere, WA
    Kubota B3200
    I have a B3200 that I personally upgraded (alternator) after I purchased the tractor. Since I had the "stock" dipstick, I made a few slight bends in it so it would fit in the available space beside the alternator. This has allowed me to access the dipstick without removing the side panels (I know Kubotas are easy on oil but I am a bit rententive - perhaps lazy, about wanting easy access when checking fluids). One question I have for you is did the dealer upgrade your tractor on site or did you order it that way? If the dealer upgraded it for you, chances are he has the stock dipstick and may just give it to you or if you ordered the tractor upgraded, they may have some laying around from other upgrades that you may be able to acquire. In short I suggest talking to your dealer about getting one - makes life easier and they are easy to replace.
    Congrats on the new tractor.
    Mike
  7. #7
    Join Date
    Jul 2005
    Posts
    187
    Mike
    The dealer changed it in their shop before they delivere
    d it. It looks to me like they might have made some bends in the di pstick
    On my 3200, the dipstick would need to be lengthend about 8" before I could reach it.
  8. #8
    Veteran Member bandit67's Avatar
    Join Date
    May 2004
    Posts
    1,539
    Foothills, Colorado
    B3000 HSDCC
    I think there is an upgraded dipstick that you can order to go with the upgraded alternator. It has been conjectured that the new, longer dipstick is supposed to be part of the upgraded alternator kit, but it doesn't always end up on machines with the new alternator. My B3030 did seem to have a slightly longer dipstick, but I still had to pull the side panel off every time I wanted to check the oil.
    The new B3000 has a much longer dipstick that I can check by just opening the hood.
    2012 Kubota B3000, block heater, filled rears, rear wheel spacers, fender extensions, LA403 w/60" bucket, BH77 w/12" bucket & mechanical thumb, Kubota pin-type QA, Kubota forks, Caroni TM1600 flail, Buhler Allied YC6010 3pt blower, Meyer 72" FEL mounted plow, Midwest LR2072 rake
    Previous machines:
    2008 Kubota B3030 (Open Station), LA403, BH75, 4 - 55w halogen front & rear ROPS mounted worklights with L39 dash switches
    2004 Case NH DX24E Subcompact
    Kubotas from Barlow's
  9. #9
    Join Date
    Jul 2005
    Posts
    187
    I had checked with the dealer, and they said that was all there was. I will check with them again and see if the B3000 dipstick would fit. They use the same engine, I believe.
  10. #10
    Join Date
    Aug 2012
    Posts
    156
    In a city in a state
    Kubota B3200
    OK, educate me on the alternator upgrade. Why upgrade, or what would it do for me?
Similar Threads
  1. D'oh- unintended 125 hour maintenance
    By pjwbx2230 in forum Kubota Owning/Operating
    Last Post: 12-19-2006, 08:38 PM
  2. Unintended benefit of BX rear remotes......
    By Junkman in forum Kubota Owning/Operating
    Last Post: 10-09-2004, 08:50 PM
  3. Unintended Consequences
    By Charlie_Iliff in forum Power Trac
    Last Post: 11-03-2003, 03:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
