Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
  1. #11
    Veteran Member rScotty's Avatar
    Join Date
    Apr 2001
    Posts
    2,064
    Rural mountains - Colorado
    Kubota M59, JD530, JD310SG. Hope to restore Yanmar YM165D
    Default Re: Kubota's Turf tires
    Quote Originally Posted by Neilzzo View Post
    Just Bought a New kubota B2920 with Turf tires, it got delivered with Kenda's Turfs in the front and Goodyear turfs on the rear both with different treed's too! Not that its a big deal, but I figured a new tractor would come with matching tires, the dealer says thats how kubota's B series are coming out with, any input will be appreciated!!!
    I've long been an advocate of turf tires for compact tractors....can't hardly believe it's been more than 30 years now! Anyway, three of my four machines have them, and the other one will too some day.
    Apparently there are several options in turf tires for your tractor. I don't know the exact brands and differences, but agree that if it was important to you then the dealer should have explained it. A few hours of use on a tractor tire won't make any difference. If it was me, I'd ask to see what options you should have been shown and at the same time I'd ask what kind of cash it would take to swap....if you want to. But you may not. Read on and I'll say why....
    What is really important in any 4wd is getting the ratio of the tire's rolling circumference correct to match the internal gear ratio in the transmission. That needs to be correct between the front and the back tires. If they need to go to different brands to accomplish that then so be it. You can check that by shifting between 2wd & 4wd.
    Some tire thoughts:
    1. If you are going to be in snow or mud, get some chains for your turf tires. Don't go aggressive; go to a modest or small size chain link but with lots of crossing bars. It doesn't take much of a chain to make a huge difference and the more crossing bars it has the longer it lasts and smoother it runs. My favorite chain is composed of small chain links with the crossing bars in an X patterns joined in the center. An good X pattern chain can run almost as smoothly as a tire.
    2. Unless you are only doing mowing on golf putting greens then you don't want Galaxy (diamond tread) type of golf course tires. Those tend to be a taller, narrower type of turf tire with almost no traction at all. You lose the traction and don't gain the center of gravity advantage.
    3. If you are doing a lot of work in the barnyard or on dirt then consider industrial tires. They are a good compromise between turf and Ag type tires. Wear like iron, too.
    4. Final thought..... If what you have on your tractor is the option with standard low profile wide turfs I'd just run those tires. You aren't going to do much better than what you have right now. Unless you are not going to mow at all and need the industrial tires there just is not enough difference to be worth a change. A basic turf tire will last a couple of decades in normal use. And your back will thank you. At least you got away from the Ag tires.....in my opinion with a compact tractor you have already gained most of the tire advantage by simply using something other than Ag tread.
    enjoy! rScotty
    We've had quite a few tractors come and go. Pride of place still goes to our 2 cylinder John Deere 530. With her QA loader, smooth draft control, telescoping 3 pt arms, power steering, clutched PTO, comfortable seat, and remote hydraulics she's as useful today as 50 years ago.
    There's a Kubota M59 & a JD310SG for TLB work. & a line-up of implements that work far better than they look.
    We'll not forget Mr. Big & Mrs. Little - 33 & 16 hp Yanmars - tough, reliable, & wonderfully clever.
  2. #12
    Join Date
    Oct 2010
    Posts
    537
    NYS--Various Parts
    Kubota B3000HSDCC, BH77, 5' Belly Mower, 6' Hyd. Angle Plow
    Subscribed.
  3. #13
    Elite Member
    Parts Supplier
    MessickFarmEqu's Avatar
    Join Date
    Feb 2004
    Posts
    5,424
    Lancaster County, PA
    Mixed brand tires on all tractors is very common. As was said, the manufacturers change brands depending on supply and pricing. The size is all that really matters.
  4. #14
    Veteran Member PHILIP8N's Avatar
    Join Date
    Sep 2009
    Posts
    1,344
    Indianapolis
    Kubota L3940 Kubota GR2120 Ford 8N Ford 6000
    Quote Originally Posted by MessickFarmEqu View Post
    I disagree. I bought a $24,000 tractor. My tires matched. If I purchase again, they will match or I will go elsewhere. Sorry, but I will not settle for excuses. This goes for cars, trucks, tractors, etc. Philip.
    Kubota L3940HST-1 2009
    84" front blade
    LA724 loader w/HD 72" round back bucket
    turf tires
    Kubota GR2120 2013
    Kubota W5019 PC
    Ford 8N 1950
    Ford 6000 diesel 1961
    Woods RD7200 finish mower, Land Pride RCR1272 rotary cutter, Land Pride RTR1274 tiller, Bearcat CH5540 5" chipper, L8170 ballast box, 6' Woods pulverizer, 6' Dragon box scrapper with hydraulic rippers, 14" 2 bottom plow, post hole auger, 7' Land Pride RB1584 rear blade, 3 point boom pole, 48" 4000# SSQA pallet forks
  5. #15
    New Member
    Join Date
    Oct 2012
    Posts
    9
    Ma.
    2012 Kubota B2920
    Quote Originally Posted by PHILIP8N View Post
    I agree with ya PHILIP8N, a 20k+ piece of equipment should at least come with matching tires, its just kubota switching from Kenda to Goodyear and want to use up their stock, nothing I can do though, the dealer said there is no other tire option for the Kubota B series in Turfs............Poor decision on Kubota's part imo.
  6. #16
    Join Date
    Sep 2009
    Posts
    1,344
    Indianapolis
    I have Titan 'the Grizz' on mine, and they all match! End users, dealers, and reps need to complain up the chain until they solve this situation. I feel for you. If you wanted to do some more research, check the Titan catalog, they have lots of sizes in there. Philip.
    84" front blade
    turf tires
    Kubota GR2120 2013
    Kubota W5019 PC
    Ford 8N 1950
  7. #17
    Join Date
    Sep 2009
    Posts
    1,344
    Indianapolis
    See if this helps any. Here are titan's catalog pages for turfs. I have the Multi Trac tire, actually says 'the Grizz' on the side wall. My tires are marked in red. Good luck. Philip.
    Attached Thumbnails Attached Thumbnails Kubota's Turf tires-tires03-jpg   Kubota's Turf tires-tires01-jpg
    Attached Files Attached Files
    84" front blade
    turf tires
    Kubota GR2120 2013
    Kubota W5019 PC
    Ford 8N 1950
  8. #18
    Veteran Member bandit67's Avatar
    Join Date
    May 2004
    Posts
    1,569
    Foothills, Colorado
    B3000 HSDCC
    On-road vehicles like cars & trucks are a completely different situation than tractors as far as tires go. On-road needs matching tires to maximize overall handling at speed.
    Turf Tractor tires can get away without having matching treads, and in some situations, can even improve traction with slightly differing tread patterns between the 2 very different sized tires front & rear, so I wouldn't lose too much sleep over it. Tire availability has been a big issue for years, and a tractor manufacturer has to do what they can to keep machines rolling off the assembly line. I'm sure they'd get a lot more complaints if buyers had to wait months just to get "matching" turf tire brands.
    2012 Kubota B3000, block heater, filled rears, rear wheel spacers, fender extensions, LA403 w/60" bucket, BH77 w/12" bucket & mechanical thumb, Kubota pin QA, Kubota forks, Caroni TM1600 flail, Allied YC6010 3pt blower, Meyer 72" FEL mounted plow, Midwest LR2072 rake, MIE ripper tooth
    Previous machines:
    2008 Kubota B3030 (Open Station), LA403, BH75, 4 - 55w halogen front & rear ROPS mounted worklights with L39 dash switches
    2004 Case NH DX24E Subcompact
    Kubotas from Barlow's
  9. #19
    Join Date
    Sep 2009
    Posts
    1,344
    Indianapolis
    Quote Originally Posted by bandit67 View Post
    Do the tires on your tractor match?
    Every tractor I see at a show (farm machinery show in Louisville), or every tractor in their brochure, has matching tires. It is a big deal to them, and it is to me too when I hand out that much money. kubota forcast their requirements to the tire manufacturers, it is not a last minute buy, better planning thru experience can take place. Philip.
    84" front blade
    turf tires
    Kubota GR2120 2013
    Kubota W5019 PC
    Ford 8N 1950
  10. #20
    Join Date
    Apr 2001
    Posts
    2,064
    I guess I don't see why it's important that the tires should match? But maybe I can learn something here. Is it just for looks or is there some other reason? Now if they were different tires on the same axle I'd agree. Heck, I might even agree if they were different colors front to back. Maybe I'm just not understanding the whole picture.....What is there about the tires that you want to match?
    I'm thinking that front and rear tires have traditionally been different on most tractors. When I think of a tractor, the mental picture that springs up is of them having different tires on the front and rear. Could be that's because I'm an older guy and automatically think of tractors are work machines; not machines made with styling as the first consideration. And since they are working machines, and since the front and rear tires do different things at different gear ratios..... then why shouldn't they have different tread, size, shape and for that matter even different rubber compounds and construction?
    rScotty
Similar Threads
  1. Tires pt-425: big 1430 tires vs. standard turf tires
    By Roswelloperations in forum Power Trac
    Last Post: 04-12-2018, 04:03 PM
  2. Ag tires vs turf tires for pulling hay wagons.
    By dezorzifarms in forum Owning/Operating
    Last Post: 06-08-2006, 11:46 PM
  3. Tires BX23 purchase with AG tires or Turf tires
    By Bricklin in forum Kubota Owning/Operating
    Last Post: 04-03-2006, 06:17 AM
  4. Tires 7610 bar tires versus turf tires
    By Koz in forum Kubota Owning/Operating
    Last Post: 06-10-2004, 02:01 PM
  5. Buying extra tires for BX23 - Turf, bar turf, bar
    By EricBX2200 in forum Kubota Buying/Pricing
    Last Post: 05-22-2004, 10:59 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
