Results 101 to 110 of 380
11-08-2012, 06:56 PM #101
11-08-2012 06:56 PM # ADS
11-09-2012, 11:39 PM #102Platinum Member
- Join Date
- Jul 2010
- Posts
- 846
- Location
- Rockland county, New York
- Tractor
- Kubota B26, John deere X595
Nice job, looks very professional. I am a woodworker myself, but was always very interested in metal work. I recently bought a welder, and currently in the market for a plasma cutter. Thermal Dynamics makes a decent one, from what I'm told.
Originally Posted by CHDinCT
2010 Kubota B26 TLB w/hyd thumb. 2004 John Deere X595 w/62" MMM.
Carl Bertuzzi
11-10-2012, 08:29 AM #103
Re: Kubota BX25D / BX70?
Carl, I should have been more specific. I didn't do the welding on that front blade. Paid a welder to do that for me and that's why it looks "professional". I have since bought a MIG/flux core welder and starting dabbling a little. I did weld up the bracket for my aftermarket remote valve and modified my 3PH draw bar so I can mount six suitcase weights when needed. Oh, and the 2" receiver tube on the bottom of the draw bar was pro-welded too, so I didn't do that. As a close inspection would reveal, there's no comparison in the consistency of the welds.
Chris
2 acres and a mule, er, Kubota BX25, and too many other toys,er, tools to list.
11-11-2012, 06:12 PM #104Veteran Member
- Join Date
- Aug 2008
- Posts
- 1,003
True..but i think the drive over deck is over pimped...i want to see a normal person do it....aka...shaft not inline etc
Originally Posted by Scooby074
"In God we trust; all others must bring data"
-Edwards Deming
11-11-2012, 07:16 PM #105Elite Member
- Join Date
- Feb 2011
- Posts
- 4,164
- Location
- Frederick County, VA
- Tractor
- Kubota BX2360 & L4240 HSTC
I thought I read that Kubota did not go with a quick connect because they wanted the deck to float. Maybe the deck on the JD does not float side to side as much as a BX?
I took the deck off my BX last week for the second time and it took 57 seconds. I could probably do it faster if I hurried.
Here is a thread with a video and pictures of my flatland.Roger
My Threads
11-11-2012, 10:05 PM #106Platinum Member
- Join Date
- Jul 2007
- Posts
- 744
- Location
- WV
- Tractor
- John Deere 1026R
I'm not going to argue about new technology or user friendliness. Y'all enjoy your machines, ya hear.
Originally Posted by 94BULLITT
11-12-2012, 12:02 AM #107
Yeah I'd like to know how "fussy" the deck alignment is in the real world too... If I would have to do it over flat concrete, then the QC wouldnt be that much of a benefit to me.
Now, if I could do it where the deck was sitting on ground that was out of level a couple inches then that changes everything.
11-12-2012, 03:12 AM #108Platinum Member
- Join Date
- Jul 2010
- Posts
- 846
- Location
- Tractor
I've seen it done on a lawn, but I would imagine the ground needs to be somewhat flat. I don't know that the ground being out of level, would make any real difference.
Carl Bertuzzi
11-13-2012, 07:16 AM #109
The issue for me with the JD autoconnect is when he deck is off the tractor. From what pic's I've seen, there's quite a bit of "machinery" that stays under the tractor and would reduce ground clearance and potentially get hung up or damaged when going off lawn. I take my SCUT into the woods quite a bit for firewood work so having highly calibrated stuff hanging down underneath would concern me. Could be wrong since I've not seen a JD 1 series with the autoconnect in person yet. I would settle for a drive over version of the Kubota deck.
I bought 4 of those triangular casters from a dollar store and just drop my deck onto them for installation / removal. Very easy to roll it under or or out from the tractor for installation on my concrete garage floor. I do still have to line up the two hangers on each side and hook up the PTO shaft, but it's not too hard.Chris
11-13-2012, 09:15 PM #110
You Kubota guys will defend your tractors to the end and then some! If you would take the time to actually look at a one series tractor and MMM it would become quite clear how the system works. The openings to line up the attachment parts are quite wide and will allow for more misalignment than a manual connect deck will allow. Yes I've owned a couple different brand manual connect decks before the AutoConnect and would never go back. I love the comment about reduced ground clearance do to MMM lift linkage! If it were Kubota, you guys would call that a "feature" to protect your vulnerable hydro fan!
Now that I've said that, I still look forward to seeing the new BX on dealer lots. I need to get a few minutes on that impressive seat.
Similar Threads
2006 Kubota B3030 4WD HST & Kubota 5' mid mount mower
By bmw2aprilia in forum Private Party AdsReplies: 1Last Post: 03-10-2012, 03:10 PM -
Kubota M4900 MFWD with Kubota LA1002 Loader, Low Hours
By Jeff Quinn in forum Private Party AdsReplies: 0Last Post: 07-02-2011, 10:05 PM -
What other model Kubota will a Front Mount Snowblow from a Kubota L275 fit on
By dourobob in forum Kubota Owning/OperatingReplies: 1Last Post: 11-17-2009, 01:27 AM -
Kubota L4400, Kubota M5040 or Kubota 3240 ? Need input!
By lemonshark2008 in forum Kubota Buying/PricingReplies: 17Last Post: 11-14-2008, 09:38 AM -
Backhoe woods bx70 backhoe
By plowster in forum AttachmentsReplies: 6Last Post: 10-01-2008, 04:31 PM
