Page 23 of 38 FirstFirst ... 132021222324252633 ... LastLast
Results 221 to 230 of 380
  1. #221
    Veteran Member CHDinCT's Avatar
    Join Date
    Jul 2008
    Posts
    2,457
    Conn. & Florida
    Kubota BX25
    Default Re: Kubota BX25D / BX70?
    Quote Originally Posted by David M View Post
    If you have rust at all, it will grow and grow until it is removed and repainted.
    Btw, to retrofit the older loaders with the pin-on types of the new loader is not recommended. Front axle is beefier on the new ones and the attach brackets on the old ones are not strong enough. Also, it costs over a thousand dollars!!!!
    David, do I assume this info is from your dealer? Disappointing that the pin-on adapter would cost $1K+. Doubt they'll sell many aftermarket at that price, or with new machines unless significantly discounted. Hope to get to a dealer after the 1st to see the set up in person and talk with a salesman. The pin-on adapter and the factory backhoe thumb both really interested me in terms of retrofits. Oh well.
    Chris
  2. #222
    Super Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    I agree Paul. Your pic with PC coming off in sheets looks very familiar.
    Its hard to beat good old fashioned paint, particularly epoxy. With proper surface prep it lasts a very long time and is super tough.Alot more money than cheap PC that any moron in the plant can apply.
  3. #223
    Platinum Member Carl Bert's Avatar
    Join Date
    Jul 2010
    Posts
    865
    Rockland county, New York
    Kubota B26, John deere X595
    Default
    Quote Originally Posted by 4shorts View Post
    Powder coating is GARBAGE! Used because its cheep and fast during the manufacturing process. No primer used or needed to apply. The only thing thats not powder coated on the Grand L's FEL is the cylinders and I've seen plenty of them around here peel. I have tooling and equipment here and lots of it most of which is either US/Canadian made and my equipment is very well cared for because I make my living with it and in all cases the powder coating failed. It peeled off in sheets. Yes in all cases. It's undiluted garbage. In some cases I've removed the powder coating and applied primer and paint via spray gun and never had an issue after.
    I've heard people say its good IF its "applied right " well EVERYTHING I have here and none of it have been applied right because its all peeled.
    I've seen a BX 1800 here at my shop that I've converted into an ice resurfacer. The hood peeled, the floor board peeled and it was on there 1/8th thick. I've seen a BX 2200 do the same. I remember the 3rd function cover on my less than 200 hour kubota GL4240 peeling and having to get the powder coating off and repaint it. I have vehicle hoists, tire changers and snowblowers here I seen the same way. Powder coating is either garbage or EVERYTHING I have here has had it applied wrong and i doubt that very much.
    Pictured is a Canadian built snow blower I had in the shop last week. Look at the powder coating on that! Yes its an extreme case and Yes it's a 6 year old unit BUT this is what happens when it do peel and not dealt with.....
    I can only speak for the equipment that I have. My B26, which is going on its 3rd year, does not have one bit of peeling, flaking or rust. My 2004 JD X595 also looks like new with zero rust or peeling, and my JD 1032D walk behind snow blower, which was my Dads and must be well over 20 years old, also is picture perfect. Granted, all my equipment is well cared for and is stored indoors. It never sits outside for any length of time, and never ever sits in the dirt.
    A lot of people let their equipment sit outside on the dirt all year round, and then complain about the paint failing. What else can you expect? I'm not saying whether or not this is your case, I am just speaking in general.
    I don't understand the fading issue though. My truck sits outside all year round and it doesn't fade, so why don't tractors have the same quality paint, at least on the hoods and fenders.
    2010 Kubota B26 TLB w/hyd thumb. 2004 John Deere X595 w/62" MMM.
    Carl Bertuzzi
  4. #224
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    Oh I'm sure that's what it is. No primer under it plus its thick. It's powder coat.
    I have one cylinder that the whole end at the gease fitting is about to break off and it has been that way since day one.
    I think the cub cadet I used to own had the floor board and deck powder coated becauce it was starting to peel. I used some truck bed coating on the floorboard were your feet go to make it look good to get rid of.
  5. #225
    Elite Member 4shorts's Avatar
    Join Date
    Jul 2008
    Posts
    3,254
    Bay Roberts, Newfoundland
    Kubota 5740,BX25D
    Quote Originally Posted by Scooby074 View Post
    Manufactures didn't use powder coating because it was more expensive and lasted longer. They used it because its cheaper and faster to apply then out the door.
    Quote Originally Posted by Carl Bert View Post
    Your truck has a UV clear coating on it. Yes it will eventually fade but it will take years. My old 1993 GMC sits outside most of the time and it still has its Original paint. I can assure you, you'd have to travel far and wide to find anyone more particular than me. I've been know to wax my tire changer
    Quote Originally Posted by 94BULLITT View Post
    I think some stuff gets paint and some gets the powder coat. Might be something that gets sourced out to different suppliers. I've seen stuff siting on lots with the powder coating peeling. It can't last with quality like that.
    Attached Thumbnails Attached Thumbnails Kubota BX25D / BX70?-image-jpg
    ...Excellence is not a skill. It is an attitude...
    Check us out on the web at www.specialtyrepairscustommods.com
    YouTube Video's: http://www.youtube.com/user/7863348?feature=guide
    2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
    2013 Kubota BX25D with many mods
    Kubota ZTR ZG 222 Z
    Custom Toyota Fork Lift
  6. #226
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    The good thing about a clear coat is it can be polished and made to look almost as good as new.
  7. #227
    Join Date
    Jul 2010
    Posts
    865
    If thats all they need to do, I can't see why they wouldn't put a coat of clear coat at least on the tractor itself. I doubt the little difference in cost would stop anyone from making the purchase, but it very well may convince others to switch brands. I know I would certainly be interested in a tractor that didn't fade rust or peel, and wasn't made of plastic.
    Carl Bertuzzi
  8. #228
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    I don't know why they don't clear the tractors. It would keep down on the orange fade.
  9. #229
    Join Date
    Jul 2008
    Posts
    3,254
    Kubota 5740,BX25D
    Actually when using clear coat it's expensive. After the base paint is applied the clear is mixed with hardener and then sprayed over the base paint BUT before you can spray the base paint you need to apply Primmer and that's an extra cost. Now do you see why manufactures use powder coating? No Primmer, no base and no clear coat. Just apply the powder and bake. They don't care if it fades. Really. They don't.
    Kubota ZTR ZG 222 Z
  10. #230
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    I think Carl was referring to clear coating painted parts of the tractor.
Similar Threads
  1. Replies: 1
    Last Post: 11-17-2009, 01:27 AM
  2. Kubota L4400, Kubota M5040 or Kubota 3240 ? Need input!
    By lemonshark2008 in forum Kubota Buying/Pricing
    Last Post: 11-14-2008, 09:38 AM
  3. Backhoe woods bx70 backhoe
    By plowster in forum Attachments
    Last Post: 10-01-2008, 04:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
