Page 35 of 38 FirstFirst ... 2532333435363738 LastLast
Results 341 to 350 of 380
  1. #341
    Veteran Member CHDinCT's Avatar
    Join Date
    Jul 2008
    Posts
    1,827
    Connecticut
    Kubota BX25
    Default Re: Kubota BX25D / BX70?
    Quote Originally Posted by Habeas Kubotas View Post
    Speaking of acquiring new BX-70 series accessories for use with earlier models, has anyone seen or heard of the new Kubota BX thumb being available for sale independent of a new BX25D? I'm very interested in looking at one for my BX25, but haven't found any leads so far. Thanks.
    The problem with adding the new OEM thumb to an older BX24/25 is that the new BX25D hoe comes with the mounting bosses already welded onto the dipper stick. You would have to have equivalent bosses welded onto your current BX, or buy a whole new dipper stick at substantial cost I would assume. Not an easy upgrade vs the FEL quick hitch.
    Chris
    2 acres and a mule, er, Kubota BX25, and too many other toys,er, tools to list.
  2. #342
    Veteran Member bandit67's Avatar
    Join Date
    May 2004
    Posts
    1,539
    Foothills, Colorado
    B3000 HSDCC
    Quote Originally Posted by CHDinCT View Post
    Yes, very expensive. I looked into that option on my BH75 hoe for my B3030 and decided it was not cost effective.
    So I went the cheaper route and traded for a whole new machine with some upgrades - cab, new FEL, new backhoe with the factory thumb already installed. Yes, much cheaper than a new dipper stick
    2012 Kubota B3000, block heater, filled rears, rear wheel spacers, fender extensions, LA403 w/60" bucket, BH77 w/12" bucket & mechanical thumb, Kubota pin-type QA, Kubota forks, Caroni TM1600 flail, Buhler Allied YC6010 3pt blower, Meyer 72" FEL mounted plow, Midwest LR2072 rake
    Previous machines:
    2008 Kubota B3030 (Open Station), LA403, BH75, 4 - 55w halogen front & rear ROPS mounted worklights with L39 dash switches
    2004 Case NH DX24E Subcompact
    Kubotas from Barlow's
  3. #343
    Member
    Join Date
    Mar 2010
    Posts
    25
    Bow, nh
    BX1850
    Kubota BX25D / BX70?-photo-mar-09-1-27Kubota BX25D / BX70?-photo-mar-09-1-28Kubota BX25D / BX70?-photo-mar-09-1-39Kubota BX25D / BX70?-photo-mar-09-1-46Kubota BX25D / BX70?-photo-mar-09-1-46Kubota BX25D / BX70?-photo-mar-09-1-54Kubota BX25D / BX70?-photo-mar-09-1-58
    Well, I said I would send some pictures, so here they are!
  4. #344
    Gold Member kcender's Avatar
    Join Date
    Mar 2010
    Posts
    449
    Nova Scotia
    B2620
    Quote Originally Posted by JHill View Post
    Click image for larger version.
Name:	Photo Mar 09, 1 27 42 PM.jpg
ID:	307382Click image for larger version.
Name:	Photo Mar 09, 1 28 27 PM.jpg
ID:	307383Click image for larger version.
Name:	Photo Mar 09, 1 39 17 PM.jpg
ID:	307384Click image for larger version.
Name:	Photo Mar 09, 1 46 00 PM.jpg
ID:	307385Click image for larger version.
Name:	Photo Mar 09, 1 46 10 PM.jpg
ID:	307386Click image for larger version.
Name:	Photo Mar 09, 1 54 31 PM.jpg
ID:	307387Click image for larger version.
Name:	Photo Mar 09, 1 58 37 PM.jpg
    Looks good.Is that a 70 series loader on a 50 series BX?If so,did everything match up all right?Just read back on the thread,I see you added the quick attach from the 70 series to the loader on the 50 series.
  5. #345
    Join Date
    Oct 2010
    Posts
    215
    NYS--Various Parts
    Airens/Simplicity/Sears
    Awesome! Thanks for posting!
    What year was your BX put into service (i.e., what "year" is it)?
    Are those the Kubota forks? They appear to allow for adjustable fork width, right? If you don't mind, may I ask how much the forks were? I understand the QA was $300.
    Do you know the weight of the QA? Of the forks? Thanks!
    Congrats!
  6. #346
    Member
    Join Date
    Mar 2010
    Posts
    25
    Bow, nh
    BX1850
    Quote Originally Posted by My Hoe View Post
    Congrats!
    It's a 2008. They are the Kubota 70 series forks, adjustable width, around 200 lbs for forks and frame, under 50 lbs for the quick attach. Just over $600 for the forks and frame
  7. #347
    Silver Member BXinNH's Avatar
    Join Date
    Aug 2008
    Posts
    139
    Southern NH
    Kubota BX24TLB
    JHill,
    That is great to see. I have a 2008 BX that I would love to put the new Kubota QA system on. I see you are in Bow, what dealer did you go through? Did they give you any trouble about selling the QA for installation on the older BX model? I'm in southern NH and will hopefully be purchasing the new QA system this summer. Thanks.
    Matt.
    Kubota BX24 TLB, Loaded R4s, Wallenstein Thumb, BXpanded Forks
  8. #348
    Member
    Join Date
    Mar 2010
    Posts
    25
    Bow, nh
    BX1850
    Quote Originally Posted by BXinNH View Post
    JHill,
    Matt.
    Matt, I bought this from Chappell tractor in Milford. I had no trouble, just that the 70 series loaders have some additional reinforcement some wheres, so basically I am on my own if the loader breaks. It essentially moves the bucket or forks 4'' forward, so I chose to take my chances for what that can add for additional stress. I am just using it to move stuff around on pallets (nothing over 300lbs), and it should be handy for brush. I don't think the hydraulics on a bx are strong enough to bend anything anyways.
  9. #349
    Elite Member 94BULLITT's Avatar
    Join Date
    Feb 2011
    Posts
    3,843
    Frederick County, VA
    Kubota BX2360 & L4240 HSTC
    Do you think there will any additional stress on the loader with the quick attach since it moves it forward it will cut down on your lift capacity?
  10. #350
    Member
    Join Date
    Mar 2010
    Posts
    25
    Bow, nh
    BX1850
    Quote Originally Posted by 94BULLITT View Post
    Right, it will add stress, and it will cut down the lift capacity; but the bx models are pretty conservative with hydraulic power compared to the strength and design of the machine. I read these forums all the time, and I've yet to hear of a bx owner who damaged their loader because the hydraulics were more powerful than the strength of the loader frame. They are designed not to pick up much weight in the first place, since the machine is so light. I am technically taking a chance, but I don't believe I will come close to damaging the loader frame if used with some common sense. The intent for me is one more of convenience for moving and storing implements (mower deck, bagger, snow blower, etc.) than to try to pick up the heaviest objects the tractor will lift. The lift capacity of an la203 loader is 408lbs 500mm forward of the pivot pin, and 613lbs at the pin, to maximum height. Now if you tried to pick up 600lbs on the tip of your forks, and keep horsing it trying to lift it, that's when you run the chance of bending something. That certainly isn't what I am going to do with it! I could be wrong, but I think the hydraulic bypass would kick in anyways, before anything could bend.
Similar Threads
  1. 2006 Kubota B3030 4WD HST & Kubota 5' mid mount mower
    By bmw2aprilia in forum Private Party Ads
    Last Post: 03-10-2012, 03:10 PM
  2. Kubota M4900 MFWD with Kubota LA1002 Loader, Low Hours
    By Jeff Quinn in forum Private Party Ads
    Last Post: 07-02-2011, 10:05 PM
  3. Replies: 1
    Last Post: 11-17-2009, 01:27 AM
  4. Kubota L4400, Kubota M5040 or Kubota 3240 ? Need input!
    By lemonshark2008 in forum Kubota Buying/Pricing
    Last Post: 11-14-2008, 09:38 AM
  5. Backhoe woods bx70 backhoe
    By plowster in forum Attachments
    Last Post: 10-01-2008, 04:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
