Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Join Date
    Nov 2007
    Posts
    840
    PA
    Kubota L3130 HST 4x4 Kubota L4740-3 HST
    Default Re: Another Tractor, need advice
    MacTractor,
    I don't think you need to worry about PTO horsepower based on my experience with a 60" 3-pt snowblower on a manual JD 750 4x4 tractor. The blower was nothing special I bought used and had it many years before selling the tractor and all the implements. The JD only had 18 hp at the pto and had manual trans with only 2 reverse gears and it did everything I needed and more. It would toss snow a good 30 feet or so. It also had turf tires and chains were used when it snowed as some of the driveways were really steep.
    Kubota L3130 HST 4x4, FEL LA723 w/QA and BH90 Backhoe
    Kubota L4740-3 Cab, HST, FEL w/Heavy duty bucket w/cutting edge
    Snow Blower: L2185 72" front mount w/hyd rotation and electric chute, 7' back blade, carry all, 48" Pallet Forks w/QA, Sun Shade, Turf tires & Rubber Chains for the winter, Extra forward and rear lighting. BearCat 73454 Wood Chipper. LandPride RCR2672 Rotary Cutter. Ballast Box Approximately 390 hours on L3130
  2. #12
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    Quote Originally Posted by MacTractor
    Thanks for the posts everyone.
    I priced out a new 3300SU here and with Loader and Blower is comes to around $20500 before tax. Tax here is 13% so the argument that was presented to me was that at $20K on the 1 year old one I would be saving the tax. ($2665)
    Again, I am in Atlantic Canada with pricing basically BS.
    So here are my options:
    1.. New 3300SU for 20.5K plust 13% Tax (Loader/Rear Blower)
    2.. New 2320HST for 19.5K plus 13% Tax (Loader/Mower/Rear Blower)
    3.. Used 2011 L3200 170 hrs for 19K no tax (Loader but no blower) Used local in Kijij (Might be too big for mowing the lawn)
    4.. User 2006 7510 180 hrs for 14.5K no tax (Loader/MMM/Rear Blower) (Blower is kind of crappy)
    The last option is to go down a notch to a BX2660, but I am not sure if this will be the best approach.
    I like the 7510 but am concerned about the 21HP for my driveway with a blower.
    Thoughts?
    I would go with the 330SU, it is only 1k more than than the 2320 and you get more power. I don't think you can have too much power for a rear blower. I think the L3200 is getting little big to mow with in some yards. If you had a BX before and always wanted something bigger now is the time to go bigger.
  3. #13
    Join Date
    Nov 2007
    Posts
    840
    PA
    MacTractor,
    I wanted to add pictures to my post above, but couldn't find them at first.
    Here's a couple of photos to show what 18 pto hp will do for reference. The blower was in Inland SA-60 with a fan of approximately 20" diameter.
    Re: Another Tractor, need advice-dsc_0398-jpg Re: Another Tractor, need advice-dsc_0408-jpg Re: Another Tractor, need advice-dsc_0420-jpg
  4. #14
    Veteran Member easygo's Avatar
    Join Date
    Mar 2007
    Posts
    1,408
    Maine
    Kubota B7800
    Considering you only have to maintain ONE acre and need loader, mower and snowblower, the B7510 should be a no-brainer. That tractor will do all the things you listed and then some. I would say if you get chains on it (it would be a must in the winter for any of tractor your options) it will be darn near perfect. I had a B7510 with turfs and it handled the following list: mow 2 acres with 60" MMM, 6' rear blade, 5' snowblower, 5" wood chipper, also hauled 4-5 cords of wood/year. Did that with turf tires and chains in the winter. I bought my B7800 because it is a little better at the firewood operation and not too big for the other tasks, but that's about it. I would suggest you save a few loonies and still get the job done with a smile.
  5. #15
    Platinum Member MF1433V's Avatar
    Join Date
    Nov 2012
    Posts
    842
    East Coast
    Massey Ferguson 1433V
    13% sales tax! Unreal!
  6. #16
    Platinum Member wcampbell47's Avatar
    Join Date
    Jul 2009
    Posts
    706
    Texas Coast
    Kubota B7510 and L3901
    The 7510 is probably more tractor than you think. I purchased mine in 2007 and have 800 hours on it. I'm from the deep south and have no experience with snow - but my 7510 has surprised me more than once on it's power and pulling ability. I'm running manual gears so I'm normally in 1st gear low range when tilling with the PTO. Down South I bought a B3200 with FEL for 16K. I went with the B3200 because it has a mid PTO. This is a sweet tractor which I use for brush cutting and lot shredding. My 7510 with MMM is a lawn tractor on steriods.
    Caution: Some of my posts may be politically incorrect.
    Kubota B7510 & L3901
  7. #17
    Elite Member GPintheMitten's Avatar
    Join Date
    Sep 2009
    Posts
    3,337
    Flushing, Michigan
    Kubota B2620 with BH65 backhoe, Ford 2N
    Default
    I'm in the 7510 camp. 21 HP and turfs are not a problem. I had a B6200 4wd (15 HP). I ran a 60" rear blower sometimes with chains. Had to go slow but with another 6 HP it would be a non-problem.
    You can fairly easily change the skids ...I did that.
    Get the 7510, add chains, get a rear blade for normal snows then switch to the blower for the big dumps.
Similar Threads
  1. New Tractor Advice
    By TomGallopavo in forum Buying/Pricing/Comparisons
    Last Post: 05-24-2012, 02:28 PM
  2. Tractor Sizing Looking for advice on what tractor I need
    By Gary_in_Indiana in forum John Deere Buying/Pricing
    Last Post: 11-26-2011, 12:50 PM
  3. In Need Of Some Tractor Advice!
    By BigBlue in forum General Lawn & Garden
    Last Post: 04-28-2008, 10:18 AM
  4. Buying Advice Need advice for a new Tractor:)
    By kcook in forum Kioti Buying/Pricing
    Last Post: 07-11-2005, 10:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
