Page 2 of 16 FirstFirst 1234512 ... LastLast
Results 11 to 20 of 151
  1. #11
    Join Date
    May 2012
    Posts
    80
    Winona, MN
    Kubota L3940; 1942 Farmall H (for sale)
    Default Re: L3940 - Order Spec - Tell me what I'm missing
    Thanks for the suggestions. I'll take a look at the winch. (EDIT--took a look. Yikes! You weren't kidding when you said they weren't cheap).
    Any thoughts on the size for a rear blade for snow removal? My driveway is about 8-9' wide with blacktop.
  2. #12
    Join Date
    Jan 2008
    Posts
    68
    Default
    If you are going to plow 1/3 mile get a front blade for the FEL. You could just get an old truck plow and modify it to fit quick attach plates. Way more useful for plowing than a rear blade.
  3. #13
    Join Date
    May 2012
    Posts
    80
    Winona, MN
    @Morning Wood. I've considered that. Plan is to eventually get a front mount snow blower but I'm still on the fence. I am getting the MPTO set up just in case.
  4. #14
    Join Date
    Sep 2007
    Posts
    64
    Indiana
    Kubota L3940HST, Kubota 7510HST (traded)
    MN + snow clearing - you are missing the cab
  5. #15
    Join Date
    May 2012
    Posts
    80
    Winona, MN
    @Stub. I know--I've thought long and hard about it. However, at least half the time I'll be in woods and from what I've read while researching, cabs and woods don't mix well.
  6. #16
    Gold Member Buppies's Avatar
    Join Date
    Oct 2011
    Posts
    265
    SouthWestern Virginia
    Kubota L 5240 John Deere 550 Gator Toro 60 in zero turn Toro 44 in walk behind
    Something along the lines of a bush hog brand 50-07 should work well. A 35-07 is to light in my opinion . Deeper snows are where this shows up. The 7ft width clears the tires when angled. The tractor size 3940 will handle either blade
  7. #17
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    13,647
    Missouri
    Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
    Sounds like you pretty well have it covered, not much on which to improve. Are you getting bucket hooks welded on? Shortly after I bought my Land Pride RCR2672, I decided to put rear guard chains, I had ordered chains on the front and rubber on the back, I really like chains; seems to spread cuttings better and nothing shoots out, so 5 feel much more comfortable mowing along roadways or around anything you don't want dinged up.
    I really like the Top and Tilt, but don't know how much it would help you, but definitely find a hydraulic top link to be the handiest thing I ever put on a tractor.
    Don't know anything about grapples, blowers or winches; Good luck
  8. #18
    Elite Member Chilly807's Avatar
    Join Date
    Sep 2009
    Posts
    2,775
    Nova Scotia
    Kubota L3400DT
    +1 on the 7 foot blade, I have a 6 foot and it's really not wide enough for snow. You want to be able to "wing" the snow back from your clearing path without driving through the ridge left from the last storm. Offsetting the blade helps, but the extra foot of blade would be nice in my case.
    I think you want at least a foot or more outside the wheel tracks on one side. Too much blade and the tractor won't pull it through deep snow. I think an 8 foot might be too much for the 3940 under heavy snow conditions, but I could be wrong too.
    Since you already have rear remotes, if you can swing the cost a hydraulic angle blade is sweet. I added that feature to mine and would never choose to be without it now. Getting down off the tractor every time you want to change the blade angle gets really old in a hurry. You may want to look for a blade that accepts plow shoes though you may not need them if your drive is paved.
    L3940 - Order Spec - Tell me what I'm missing-dsc00677.jpgAttachment 294714
    Chains are probably going to be a wish item.. the tractor works better with them on snow or ice.
    Sean
  9. #19
    Join Date
    May 2012
    Posts
    80
    Winona, MN
    @TripleR: I hadn't thought to ask about hooks. I will now. Thanks.
    @Chilly: Re: hydraulics. I'm on the fence--my budget is already ballooned. I'm looking at LP blades (dealer carries and can wrap into financing) and I believe a number of them have an add on kit I could add. I'll look at the cost.
  10. #20
    Platinum Member PHILIP8N's Avatar
    Join Date
    Sep 2009
    Posts
    986
    Indianapolis
    Kubota L3940 Ford 8N Ford 6000
    I used a rear blade for years to clean snow from blacktop driveway. Works okay, but for deep and heavy snow, not the best. I got front mount blade when I got my L3940, works great. If you are set on rear mount blade, Land Pride makes a nice heavy duty unit, RB1584, nice size and weight for L3940. I added the hydraulic angle myself. Philip.
    Attached Thumbnails Attached Thumbnails L3940 - Order Spec - Tell me what I'm missing-bblade02.jpg   L3940 - Order Spec - Tell me what I'm missing-bblade01.jpg   L3940 - Order Spec - Tell me what I'm missing-dscn0639.jpg
    Kubota L3940HST-1 2009
    84" front blade
    LA724 loader w/quick attach
    HD 72" round back bucket
    turf tires
    Ford 8N 1950
    Ford 6000 diesel 1961
    JD LX188 1997
    JD L110 2003
    Woods RD7200 finish mower, Bearcat CH5540 5" chipper, L8170 ballast box, 6' Woods pulverizer, 6' Dragon box scrapper with hydraulic rippers, 14" 2 bottom plow, sub-soiler, post hole auger, 3 point pallet forks, 3 point 2" drawbar receiver, 30" rear scoop, 7' Land Pride RB1584 rear blade, 3 point boom pole
Similar Threads
  1. 3320Power Beyond spec?
    By OrangeJbird in forum John Deere Owning/Operating
    Last Post: 12-22-2012, 08:10 PM
  2. Spec
    By bensfarmingchannel in forum Yanmar
    Last Post: 08-12-2012, 05:39 PM
  3. Loader spec
    By Rexnfx400 in forum Yanmar
    Last Post: 12-19-2005, 02:06 PM
  4. Cancelled my Century Order, placed a Branson Order
    By MinnesotaMan in forum Zetor, Century & Branson
    Last Post: 07-04-2004, 03:02 PM
  5. Ready to Order This Month - But what to order?
    By catsco in forum Power Trac
    Last Post: 05-14-2004, 01:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
