Results 21 to 24 of 24
02-05-2013, 06:03 PM #21Platinum Member
- Join Date
- Feb 2002
- Posts
- 526
- Location
- Connecticut
- Tractor
- BX2360/ Cat 287B/ Kobelco 115SR/ Kubota 161-3
Re: Looking to purchase a Kubota L35
I hope I didn't make it sound like the hoe was hard to remove always....its only difficult IF it was never removed and the levers and locking mechanism are seized. Other than that its a snap to remove, just try to do it on hard, level ground or it may give you a small fit when trying to re-install it.
Kubota BX 2230, Cat 287B MTL, Kubota 161-3, Kobelco SK115SR
02-05-2013, 09:56 PM #22New Member
- Join Date
- Jan 2013
- Posts
- 23
- Location
- Nanaimo, BC
- Tractor
- Kubota B7001
No problem Tags, ALL!!!! comments are welcome be me as I am new to tractors and backhoes. I lived on a farm as a kid but most of our stuff then was done with horses.
02-05-2013, 10:01 PM #23Veteran Member
- Join Date
- Apr 2002
- Posts
- 1,814
- Location
- Coastal NH
- Tractor
- 01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
Tags/ Don,
What these older machines have (mine included) is the lever and top clamping mechanism for the BH - the new Kubotas have a pin that goes in the bracket - needs to be lined up perfectly to slide the pin in.
The new system is solid no question, but the old clamp system is easier to use and install IMO. The cost to machine all the parts and blocks, springs, and levers was probably 5-10X the current system so I understand why Kubota made the change.Kubota B21TLB, Ferris IS2000, Cub Cadet 1811
02-05-2013, 10:01 PM #24Veteran Member
- Join Date
- Apr 2002
- Posts
- 1,814
- Location
- Coastal NH
- Tractor
Tags/ Don,
Similar Threads
Price Check Kubota L35
By cannonfodder999 in forum Kubota Buying/PricingReplies: 0Last Post: 12-31-2011, 11:39 PM -
Oil & Fuel L35 kubota
By Brian m in forum Kubota Owning/OperatingReplies: 3Last Post: 05-08-2011, 09:32 PM -
S/N on Kubota L35
By jleo1 in forum Owning/OperatingReplies: 4Last Post: 04-18-2011, 07:05 AM -
Kubota L35
By rmk700 in forum Buying/Pricing/ComparisonsReplies: 2Last Post: 03-31-2011, 09:24 PM -
kubota L35
By dnj12345 in forum Parts/RepairsReplies: 22Last Post: 03-21-2010, 08:14 PM
