Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Platinum Member Iowan's Avatar
    Join Date
    Oct 2012
    Posts
    713
    North Central Iowa
    Kubota's
    Default L3430GST The Good,The Bad and The Ugly
    Hi all, I'm looking for an L series with a heavy loader for my tilling business. the new L4600 would work great but at almost thirty grand its not going to happen. I have found a L3430 with 500 hrs and a LA723 loader with a 72in hd bucket that might work. My plan is to use a 60in tiller and a center mount scraper blade on the tractor. I will also use a rock bucket and a 400lbs land plane-drag on the three point. My question about the L3430GST is what is the the good bad and the ugly about this tractor, Ive herd there's problems with the L's three point being jerky, and the L3430 is under powered.
    So if you love it or hate it please let me know.
    Thanks, Iowan
  2. #2
    Platinum Member High Compression's Avatar
    Join Date
    Aug 2010
    Posts
    565
    De Soto, KS
    Kubota L5740-3/ Kubota ZD21 pro60
    Default Re: L3430GST The Good,The Bad and The Ugly
    Yes the smaller L's have jerky 3pts. The larger Grand series L's are flawless. How about a B series? And what's wrong with your BX2660. Great machine. Loader not lift enough? How much do you need to lift?
    No matter which way you go, there will be sacrifices. Pro's and con's. Size, weight, maneuverability, lift capacity, etc.
    "It is better to be thought a fool, than to open your mouth and prove it."
  3. #3
    Elite Member nybirdman's Avatar
    Join Date
    Feb 2009
    Posts
    3,817
    north of upstate ny
    Kubota L4240 HSTC,L3000DT
    The 3430 is a Grand L.You won't have a problem with the three point.I had a L3130 HST and was a great all around tractor.The L3430 has a little more HP,you won't have any problems with the implements listed.A few people complained about power when loaded with a back-hoe,adds a lot weight.I also had the 723 loader,which is the larger of the two offered for this machine;hours are low also for the year(about 2004).If the price is right buy it ,you won't be disappointed.
  4. #4
    Join Date
    Oct 2012
    Posts
    713
    North Central Iowa
    Kubota's
    Quote Originally Posted by High Compression View Post
    The BX has it's place, gardens and most laws in town, but the jobs are just getting to big for the the BX. I remove concrete, retaining walls, move large amount's of dirt and gravel for new construction etc. a back hoe will be needed at sometime. This will not replace the BX but will bet an addition to it.
    Also this tractor would be a compromise, an L4600 could run a 72in tiller.
    Thanks, Iowan
  5. #5
    Join Date
    Feb 2009
    Posts
    3,817
    north of upstate ny
    Quote Originally Posted by Iowan View Post
    Thanks, Iowan
    My L3130 ran a 72" tiller with no problem.....and we have some of the toughtest soil conditions around,the rock garden north-east.
  6. #6
    Join Date
    Oct 2012
    Posts
    713
    North Central Iowa
    Kubota's
    Quote Originally Posted by nybirdman View Post
    Thanks again, that's great to hear. This tractor is at a good price has two remotes a quick attach loader, the only thing to deal on yet is the wheel and tires, Id like R1s on it it has R4s on it now.
  7. #7
    Join Date
    Apr 2012
    Posts
    743
    pa
    kubota 7040sud
    at 30k for a 4600 kubota i would run
  8. #8
    Join Date
    Feb 2009
    Posts
    3,817
    north of upstate ny
    I have had R1's on my tractors,tough switch to R4's/R1's they require different rims.Maybe able to swap with some-one/dealer looking for R4's.If you are thinking of adding a back-hoe you may want to stick with the R4's.
  9. #9
    Join Date
    Oct 2012
    Posts
    713
    North Central Iowa
    Kubota's
    Looking to buy a complete set of wheels and tires (R1s) with tractor, I will have both R1s and R4s. If you buy sets from your dealer they are cheaper than the tires alone.
  10. #10
    New Member
    Join Date
    Jun 2012
    Posts
    16
    Southeast, Ohio
    Kubota L3430HST
    The L3430 is a great medium sized compact tractor that can handle what ever comes it way. Sure, there are times I want a little more horsepower, but considering the nimbleness of its size, even with a backhoe, I have learned that there are tradeoffs in life. I looked at the MX5100 this past year, but after careful consideration, and with the help of others here, I decided that there is always something bigger, and while the bigger tractor will do a few more things than a 35 hp tractor, it will also use more fuel and take a bigger truck to trailer it.
    The hitch on mine works smoothly and while the L4330 and up had a larger loader series, the LA723 still lifts an impressive amount (1500+ lbs bucket bottom), and there are times that I can lift more with the FEL than the muddy ground under the front wheels wants to hold up without leaving ruts.
    One other item, the L30 Series Operators Manual list the 60" tiller as the max, but I am glad to hear the the L3130 ran at 72" tiller in tough ground.
    L3430GST The Good,The Bad and The Ugly-p3270123-jpg
    Kubota L3430HST with LA723 FEL and BH90 Backhoe for working
    ZD21 for mowing
    RTV900 for cruising
    1990 Jeep Wrangler for fun!!
Similar Threads
  1. JD 5055E, Good, Bad, & Ugly?
    By LRTX1 in forum John Deere Buying/Pricing
    Last Post: 01-27-2010, 09:34 PM
  2. YM2010 - the good, the bad, the ugly?
    By Philip_L in forum Yanmar
    Last Post: 06-05-2007, 10:34 AM
  3. JD 990 Good -Bad - Ugly
    By madmac in forum John Deere Owning/Operating
    Last Post: 06-17-2005, 03:13 PM
  4. Snakes, The Good, The Bad, and the ugly
    By LSmith in forum Rural Living
    Last Post: 12-20-2004, 11:34 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
