Page 7 of 17 FirstFirst ... 45678910 ... LastLast
Results 61 to 70 of 164
  1. #61
    Member eb542's Avatar
    Join Date
    May 2008
    Posts
    25
    Default Re: New B3350
    [QUOTE=ericdube;3243248]Nice! So kubota added a turbo on this model after all. Now I wonder how it's going to sound!
    He also mentioned that the B2650 is actually just under 26 hp to keep it below the minimum hp for requiring tier 4 emissions equipment (so there's no DPF on that engine.) From what little he said about it, it sounded to me like it was nearly identical to the existing 3-cylinder engine that's on B-Series today. QUOTE]
    B2650 - Engine model D1305
    B2630 - Engine model D1105
    Not so sure about the two engines being "nearly identical". I will look up a few key part number to confirm.
  2. #62
    Gold Member ericdube's Avatar
    Join Date
    May 2010
    Posts
    333
    Massachusetts
    Kubota L4760
    Quote Originally Posted by eb542 View Post
    D1305 is the same displacement engine as the B2920, however, it's just not the first 5 digits that matter here. The E4 denotes Tier 4 Emissions (whereas the B2920 is Tier 3), so the engine is probably also somewhat derated.
    Edit: FWIW, I looked up both engines in the on-line parts diagrams and even though the crankcases do look nearly identical they actually have different part numbers (so I'm guessing they probably made some minor modifications for emissions purposes.) However, almost all the rest of the surrounding engine parts are the same and interchangeable between the two tractors.
  3. #63
    Join Date
    Jun 2012
    Posts
    65
    CT
    2013 John Deere 1026R TLB
    Default
    So the 50 series are cab tractors? What are the non cab models? Are the 2320, 2620, and 2920 sticking around as the non cab models?
  4. #64
    Veteran Member bandit67's Avatar
    Join Date
    May 2004
    Posts
    1,553
    Foothills, Colorado
    B3000 HSDCC
    I'm sure there will be non-cabbed versions of those machines, size & power wise, probably with new numerical designations. The 2x20 series are smaller machines, so they are not/will not be the non-cabbed versions of the new B 50 series.
    2012 Kubota B3000, block heater, filled rears, rear wheel spacers, fender extensions, LA403 w/60" bucket, BH77 w/12" bucket & mechanical thumb, Kubota pin-type QA, Kubota forks, Caroni TM1600 flail, Buhler Allied YC6010 3pt blower, Meyer 72" FEL mounted plow, Midwest LR2072 rake
    Previous machines:
    2008 Kubota B3030 (Open Station), LA403, BH75, 4 - 55w halogen front & rear ROPS mounted worklights with L39 dash switches
    2004 Case NH DX24E Subcompact
    Kubotas from Barlow's
  5. #65
    Member
    Join Date
    Apr 2012
    Posts
    44
    mt
    kubota
    Didnt know there would be non cab versions good to know
  6. #66
    Join Date
    May 2004
    Posts
    1,553
    Foothills, Colorado
    B3000 HSDCC
    Well, I'm not saying that I actually know for sure, but since the non-cabbed Bxx30 series were such big sellers, I would highly doubt there would not be new non-cabbed versions of the Bxx50 series.
    Previous machines:
  7. #67
    Elite Member
    Parts Supplier
    MessickFarmEqu's Avatar
    Join Date
    Feb 2004
    Posts
    5,377
    Lancaster County, PA
    I stand corrected. Thanks guys :-)
  8. #68
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    2,277
    Canada
    B3200, L5740,
    Just for fun I like to run through the parts book which is what I did for the B3350. I does have a turbo and a whole lot of other junk added for emissions. Huge expense has been added to this engine just to satisfy the EPA. When I compare it to the B3300 that is the same HP and base engine it strikes home why the T4 engines cost so much more.
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    ZD1211
    GF1800 sold
    Kubota RTV900
    JD 850D Gator sold
    JD F935 x 2 sold
    Case 590SM-2
    JD 310D TLB sold
    Ford 555D sold
    Gehl 602 excavator sold
    JD317 sold
    JD323D
  9. #69
    Join Date
    Jun 2004
    Posts
    1,759
    Northeast MA
    Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
    Gettin' itchy.
    Anybody heard any new news on these? When they're coming out?
  10. #70
    Join Date
    May 2010
    Posts
    333
    Massachusetts
    Kubota L4760
    Quote Originally Posted by jim_wilson View Post
    Gettin' itchy.
    The last update I received today is still sometime in May (my dealer has two on order that are suppose to be arriving around then.) One is spoken for already (the owner is buying it), and I'm debating on putting down a deposit on the other one.
    However, I still need to work out the height issue with my existing garage door opening. Depending on tire air-pressure of the B2650/B3350, the height of the tractor with R4 tires falls right around 83-83.5". The door is at 82", but I think if I relocate the garage door tracks higher and cut out the opening some more I should be able to get around 84.5", which should give me an inch to spare (enough for weatherstripping.)
    Also, the loader-mounted hydraulic plow I wanted I don't think is available yet still.
Similar Threads
  1. Kubota B2650 & B3350
    By ericdube in forum Kubota Buying/Pricing
    Last Post: 08-13-2014, 10:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
