Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Member kootenai's Avatar
    Join Date
    Mar 2013
    Posts
    37
    North Idaho
    '07 Kubota L3400. Woods: Tiller, Back Blade, Box Blade, Backhoe
    Default L3400 HST-F is this 4wd?
    Hi Gang,
    I found a low hour L3400. For the life of me (and I was a little road weary) I could not find the shifter for 2wd - 4wd. A cursory search on tractor data suggests that there is only 4wd with HST. Is this an "All time" 4 wd? Or what gives, am I blind? I have included the Model number in the photo to expedite an answer from those of you in the know......
    L3400 HST-F  is this 4wd?-img_1310-jpg
  2. #2
    Elite Member Baby Grand's Avatar
    Join Date
    Nov 2007
    Posts
    4,582
    Windsor, CT.
    Kubotas: L3240GST B2320HST B5100D & G5200H
    Default Re: L3400 HST-F is this 4wd?
    I believe the Fs are 2wd with FST - full synchro tranny (manual),
    the DTs are 4wd with FST,
    the HSTs are 4wd.
    If it's 4wd (DT), then there should be a lever, down low, to the left, just behind your left heel when you're sitting in the seat.
    Down for dirt; up for asphalt.
    For some reason, the kubota website isn't showing the L3400 in the previous model listing ....
    That's the problem with trouble.
    It always starts out as such fun."
    - Randall Brown
  3. #3
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,265
    Central Ohio
    Kubota MX5100
    Unless the HST is different, mine is on the centerhump to the left a bit and tucked under the seat almost.
    And on mine, its down for asphalt (2wd) and up for dirt (4wd)
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  4. #4
    Join Date
    Jan 2008
    Posts
    2,383
    Western PA
    John Deere 5083E MFWD, Kubota L3400 HST
    Quote Originally Posted by LD1 View Post
    x2, its an orange t-handle on my machine.
    '11 John Deere 5083E, 563NSL Loader, MX10 Mower, 78" Bucket, Forks/Bale spear (interchangeable)
    L3400 Kubota HST Loader, finish mower, rake, scraper blade, Gin pole, Kustom Fab front hydraulic snow plow (Inspired by ASGAR)
    JD 550 Dozer 6 way blade and winch
    JD 450B Track Loader
    Case 480C Backhoe W/ Extend-a-hoe
    '01 International 4700 LP, DT530, Allison MD3060, Air Ride, Crew Cab
    '11 Moritz 20+5 14.5K GN with adj. Tail
    ''08 700R Raptor
  5. #5
    Join Date
    Mar 2013
    Posts
    37
    North Idaho
    Well OK, thanks for not coming out and saying it, but I must be blind. I searched all over for that knob. I thought, that's a mighty nice tractor to NOT have 4wd. Glad I am wrong... Now, off to solicit input as to whether it is a good deal.
  6. #6
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,343
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by kootenai View Post
    Also just look at the front axle, does it have final drive cases down low? (4wd)or is it a solid axle ? (2wd) on the right hand side upper side is fill port for oil for the axle?(4wd) Crawl under the engine, does the oil pan have a tunnel for the front driveshaft? (4wd) What do the front tires look like? Ribbed (2wd)
    On the one I had, it was HST with 4wd, and had a T handle by your left heel to shift from 2wd to 4wd
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  7. #7
    Join Date
    Jan 2008
    Posts
    2,383
    Western PA
    No problem. there must be a secret society that designs the 4wd enagagement controls. I dont think I have ever been on two tractors that it was the same between them! Its even worse between seperate brands!
    ''08 700R Raptor
  8. #8
    Join Date
    Mar 2013
    Posts
    37
    North Idaho
    Quote Originally Posted by RedNeckRacin View Post
    Found it!
    I thought it was a seat adjustment, I had to have the seller take a picture and send it. L3400 HST-F  is this 4wd?-dscn2510-jpg
  9. #9
    Join Date
    Jan 2008
    Posts
    2,383
    Western PA
    IT WAS CAMOUFLAGED!!! Organge blends in with orange nicely. If you try it out, don’t engage it while you’re moving, it’s not a synchronized gear set.
    ''08 700R Raptor
  10. #10
    Join Date
    Jun 2009
    Posts
    28,343
    Branson, Mo.
    Found it!
    Thats the one!
    James K0UA
Similar Threads
  1. Buying Advice Kubota L3400 HST or Mahindra 3316 HST
    By DownNotOut in forum Buying/Pricing/Comparisons
    Last Post: 04-03-2010, 08:22 PM
  2. Price Check Price to trade from L3400 gear to L3400 HST
    By westbrooklawn in forum Kubota Buying/Pricing
    Last Post: 03-13-2010, 08:20 AM
  3. MX5000 2wd vs L3400 4wd
    By V8ZRACER in forum Kubota Buying/Pricing
    Last Post: 08-11-2005, 05:29 PM
  4. What model JD is equivalent to L3400 HST 4wd ?
    By bota3400 in forum Kubota Buying/Pricing
    Last Post: 06-14-2005, 08:07 PM
  5. Bought a Kubota L3400 4wd dt w/bucket. Mistake???
    By smittyd3 in forum Kubota Owning/Operating
    Last Post: 12-20-2004, 06:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
