Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Jul 2006
    Posts
    6
    south central Iowa
    none yet
    Default Which tractor
    I have about 20 acres, of which about 15 needs to be cut with a rotary cutter. The land to be cut is on a sloping hillside but not too steep to cut parallel to its slope with no danger of rollover. I have a driveway about a quarter of a mile long that I have to maintain, but only with occasional snow removal. I would also use a front end loader for various uses and am considering using it on the rare occasions when I have to remove snow from the driveway.
    Which kubota tractors and implements would you recommend. Cost is a factor.
    Thank you.
  2. #2
    Platinum Member KYDan's Avatar
    Join Date
    Sep 2011
    Posts
    770
    Frankfort, KY
    Kubota MX5100 HST 4WD
    Default Re: Which tractor
    Speak to your local dealer, most likely something in the B series or lower horsepower L series if you want a cab. I have found most dealers will be glad to assist with what model would suit you best. Usually, they are in for the long haul and will not sell you something that won't suit your needs based upon stock in hand.
  3. #3
    Elite Member
    Join Date
    Dec 2007
    Posts
    3,213
    texas
    7040 HDC 1153 fel
    hilly pasture id prolly go with a 4wd drive in the 3200 or 3400 line of tractors.
  4. #4
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    6,953
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds operating weight
    I have a kubota B3300SU that I remain enthused about after a year. My first tractor/loader, it comes as a complete package: FEL, 4-WD, HST and almost standard R4 "Industrial Tires". I do a lot of woods work and "B" maneuverability is a big plus. B3300SU also has high ground clearance and a flat floor in the cockpit.
    The attachments I use most:
    Ratchet Rake (does everything)
    Ken's bolt on bucket hooks for 5/16" chains
    Bucket Spade
    Wallenstein BX42 PTO chipper
    King Kutter 'hog
    Bush Hog Rollover Box Blade
    I have not needed snow removal equipment.
    I would early opt for aftermarket Stabilworks rigid stabilizers to replace the factory check chains/turnbuckles early on. Stabilwork's mechs not only make loading implements MUCH easier, they also reinforce the lower links when pushing in reverse with KK RM and ROBB.
    You can "search"/titles the TBN data base for B3300SU or any of the implements and find a day's worth of reading and videos. You may even find a few opinions.......
    My Kubota dealer was MOST HELPFUL in helping me select the B3300SU out of the mass of orange eqiupment on his lot.
    Attached Thumbnails Attached Thumbnails Which tractor-img_0606-jpg   Which tractor-img_0327-jpg   Which tractor-img_0428-jpg   Which tractor-img_0489-jpg   Which tractor-img_0488-jpg
    Which tractor-img_0496-jpg   Which tractor-img_0478-jpg   Which tractor-b3300su-001-jpg   Which tractor-img_0463-jpg
  5. #5
    Elite Member nybirdman's Avatar
    Join Date
    Feb 2009
    Posts
    4,014
    north of upstate ny
    Kubota L4240 HSTC,L3000DT
    HST and 4wd,largest FEL/bucket offered.B2620-B2920,L3400-L3800 up to the L3240.All depends how much you want to spend and how many features you would like.Hint;buy one size larger than you think you will need.They tend to shrink with use.You are going to need a brush-hog and maybe a rear scraper blade for driveway/snow.Good luck shopping.
  6. #6
    Join Date
    Feb 2013
    Posts
    647
    Thornville, Ohio
    No longer Searching. Mahindra 3016 Shuttle
    vic6,
    Do you intend to do anything beyond mow and maintain the property, like raise crops or livestock?
  7. #7
    New Member
    Join Date
    Jul 2006
    Posts
    6
    south central Iowa
    none yet
    We will only need the tractor for mowing and property maintenance. No crops or livestock. We do have two horses but have never needed a tractor to take care of their needs.
  8. #8
    Join Date
    Feb 2013
    Posts
    647
    Thornville, Ohio
    vic6,
    As others have said, most any of the current "B" or "L" series tractors should meet your needs. Definetly a front loader if at all possible. A rear blade and a rotary cutter sized for your tractor are basic implements that you will use often. Both of these are available used at a savings over new. I think most will agree with me, on these small compact tractors, 4wd is a necessity.
    You can find either a "B" or "L" tractor used with low hours, 1000hrs or less, at a fair price. Use "tractordata.com" to research older tractors, horsepower, transmission etc.
    Are you wanting to finish mow your lawn as well with this tractor? Because tire choice will be important. Ag Tires (R1) are much preferred for rotary cutting on your slopes, but will damage your lawn. Turf Tires (R3) are only good on lawns and very poor in winter snow or mud. Industrial tires (R4) are a compromise, but even then you should have tire chains for snow.
Similar Threads
  1. Replies: 7
    Last Post: 12-09-2012, 08:09 PM
  2. Replies: 3
    Last Post: 10-30-2012, 07:51 PM
  3. Peer review/help for BX size tractor as multipurpose yard tractor
    By imajeepnut in forum Kubota Owning/Operating
    Last Post: 04-12-2009, 08:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
