Results 1 to 7 of 7
  1. #1
    Gold Member displacedPA's Avatar
    Join Date
    Apr 2011
    Posts
    395
    SC
    NH T2310
    Default B2320 remote kit
    well I emailed messicks about a valve kit for top&tilt.
    Here are the part numbers he gave me. Im wondering if this is the kit that mounts on the rops or something different?
    You need
    B7309B (1st position valve and hose) - $700
    BL7343 Stacking Kit - $50
    BL7373 detent valve - $380
    Or
    BL7393 float valve - $310
    I know this has been discused in the past just wondering if anyone has used these part numbers and can tell me what and where they mount.
    Thanks,
  2. #2
    Gold Member ericdube's Avatar
    Join Date
    May 2010
    Posts
    333
    Massachusetts
    Kubota L4760
    Default Re: B2320 remote kit
    While I don't know those specific part numbers, the only "kit" available that I've ever see for a B20 series is for attachment to the ROPS. Otherwise, those part number descriptions make sense to me (first valve and option for second valve + stacking kit.) You just need to decide if you want double acting detent or detent with float option for the second remote valve.
  3. #3
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Are you really serious about those parts from kubota?
    You do know that you can do better with stacked valves from Surplus by about half that price.
    $537.85
    http://www.surpluscenter.com/cart.asp?catname=hydraulic
    Attached Thumbnails Attached Thumbnails B2320 remote kit-surplus-center-4-spool-sv
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #4
    Member
    Join Date
    May 2012
    Posts
    28
    Cashmere, WA
    Kubota L3301 TLB
    I mounted a 3-spool valve on my B3200 this winter to operate a pull grader with 6-way hydraulics. I will post up a picture tomorrow of how it attaches to the ROPS. The hardware and mounting should be the same for both machines although the plumbing may differ slightly depending on whether you have a BH attached (I do). It would be the same for a 1-valve spool - you can always add more down the road
  5. #5
    Join Date
    Apr 2011
    Posts
    395
    SC
    NH T2310
    Quote Originally Posted by J_J View Post
    $537.85
    Burden Surplus Center
    Yea this is the kit I was looking at before. I think you had recomended it a year ago JJ. I was just curious if the kubota kit was revised yet. I will go after market for this Im sure.
    AC
  6. #6
    Member
    Join Date
    May 2012
    Posts
    28
    Cashmere, WA
    Kubota L3301 TLB
    As promised here are a few pictures of a 3-spool stacked valve attached to my B3200. I have one double acting detent and two float detent valves + power beyond (for the BH). Initially I looked at getting a separate spool, as others have mentioned, it is cheaper but by the time I added in the hoses and tractor connections which are inlcuded in the kit I couldn't beat the price my dealer gave me.
    Mike
    B2320 remote kit-b3200_3-spool_1-jpgB2320 remote kit-b3200_3-spool_2-jpgB2320 remote kit-b3200_3-spool_3-jpgB2320 remote kit-b3200_3-spool_4-jpg
  7. #7
    Silver Member Burtonbr's Avatar
    Join Date
    Nov 2012
    Posts
    137
    NC
    Kubota b2620, LA364 loader.custom rear remotes, THUMB bucket grapple, 60" box blade 72" landscape rake &many other toys
    I didn't like the looks or price of the kit so I followed a few others lead here and added rear remotes with a valve from surplus center. I think I saved $200 by doing it myself and it wasn't that difficult once I got everything figured out that was needed.
    Attached Thumbnails Attached Thumbnails B2320 remote kit-image-jpg   B2320 remote kit-image-jpg
Similar Threads
  1. Price Check B2320 fel,mm,hoe
    By fordkub in forum Kubota Buying/Pricing
    Last Post: 12-14-2011, 08:33 PM
  2. new B2320 is here
    By displacedPA in forum Kubota Owning/Operating
    Last Post: 08-08-2011, 10:06 PM
  3. Buying Advice B2320 or ?
    By Flying MXZ in forum Kubota Buying/Pricing
    Last Post: 03-30-2010, 07:22 PM
  4. New (To Me) B2320 HST
    By Iowachild in forum Kubota Buying/Pricing
    Last Post: 08-22-2009, 10:08 AM
  5. New B2320
    By schipman in forum Kubota Owning/Operating
    Last Post: 12-10-2008, 07:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
