Results 1 to 8 of 8
  1. #1
    Member
    Join Date
    Jun 2013
    Posts
    33
    Madison, Ga
    Kubota L3200HST with LA524 Loader, Quick Connect; Loaded R4 Tires
    Default 5' Howse Box Blade and 5' Howse Bush Hog
    I saw this as part of a package deal with a new L3200HST w/loader and an 18' 7K trailer for $20,100 cash. Can anyone tell me about the quality of these Howse implements and whether this is a good price?
  2. #2
    Super Member s219's Avatar
    Join Date
    Dec 2011
    Posts
    6,559
    Virginia USA
    Kubota L3200 Deere X380 Kubota RTV-X
    Default Re: 5' Howse Box Blade and 5' Howse Bush Hog
    I have a Howse box blade, and the quality is outstanding. It is a heavy duty construction, with thicker steel than any other box blades I looked at. My local dealer (Dubberly Tractor) has a similar package for $20,200, and I know they are very competitive with pricing.
  3. #3
    Elite Member oldballs's Avatar
    Join Date
    Dec 2009
    Posts
    2,921
    Kansas...USA
    Kubota B2620 , Case 448 Kubota B2650
    Did you say that the Tractor + FEL + Trailer + Hog + BB totals is $20,100? Wow!!
    Kubota B2620 HST (2012) Case 448(1983)
  4. #4
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,033
    Central Ohio
    Kubota MX5100
    Thats not a bad deal at all.
    Howse makes good stuff.
    BUT...if I were you, I'd throw another few hundred at the deal and get a 20' trailer (and possible even consider upgrading to 10k).
    A 18' 7k trailer is right at the limit of a 3200.
    Tractor...................2600#
    Loader and bucket....1200#
    Loaded tires.............600#
    Heavy implement.......800#
    Total.....................5200 give or take.
    that leaves NO room for anything extra. And not that you would have the room on a 18 trailer anyway.
    I have a 3400 (same tractor basically), and a 5' hog is a squeeze on it. And a 6' requires backing on and setting the tailwheel darn near on the hitch. An no room to shift for balancing a load properly.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  5. #5
    Join Date
    Jan 2012
    Posts
    1,870
    Success Missouri
    Kubota L3800DT, L3750DT Shuttle
    Same general price here will get you a L3800 package deal with Land Pride attachments.
    Howse makes good stuff though...
    Don
    Kubota L3750 Hydro Shuttle, 4wd, FEL; L3800 Gear drive, 4wd, FEL
    Husqvarna XP chainsaws 346xp X3, 357xp, 562xp, 359
  6. #6
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    40,561
    Texas
    I don't know how much they've changed, but in 1999, I had both the Howse 500 (5' rotary cutter) and the 5' Howse box blade to use on my B2710 kubota. Had no complaints with either.
    Bird
  7. #7
    Join Date
    Nov 2011
    Posts
    192
    Red Springs, NC
    Kubota L3700SU
    Never had Howse brand equip. My thought is, I agree with LD1 on the trailer. Not only is it close on weight with your equipment you will find many uses for the trailer and will never regret getting the heavier axles and few extra feet.
  8. #8
    Silver Member shucksters's Avatar
    Join Date
    Mar 2013
    Posts
    191
    TN
    Kubota L4240 HST+ FEL C/A Kubota BX2370 + FEL/60"MMM Kawasaki Mule ProFXT EPS LE
    Quote Originally Posted by Atlanta Panther View Post
    I have had a Howse 7' Box Blade for 12 years working a sand mix horse arena and 150 yard gravel driveway. I've only replaced the teeth once and the support is awesome.
Similar Threads
  1. Howse bush hogs
    By RJJR in forum Attachments
    Last Post: 04-28-2012, 10:00 PM
  2. Rotary Cutter Howse 8' 3PH (Bush Hog style)
    By gwdixon in forum Attachments
    Last Post: 04-04-2011, 11:23 PM
  3. how do I get the blades of a Howse 5 ft bush hog?
    By corvettefarmer in forum Attachments
    Last Post: 03-28-2010, 10:40 PM
  4. Rotary Cutter howse model 500 bush hog
    By jmt1271 in forum Attachments
    Last Post: 04-08-2007, 04:37 AM
  5. Howse bush hog
    By allpontiac in forum Owning/Operating
    Last Post: 01-17-2005, 08:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
