Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Jun 2013
    Posts
    5
    Watertown, Mn
    Farmal C
    Default 1988 kubota L3350 on auction
    072 - YouTube
    Does the engine sound alright? It has 2400 hrs on it. Any thing I should look out for?
  2. #2
    Elite Member rbargeron's Avatar
    Join Date
    May 2000
    Posts
    2,807
    MA
    L5450, L48, L3250, L345
    Default Re: 1988 kubota L3350 on auction
    This is one of the legendary L3 machines - very heavily constructed, much more tractor than the model number suggests. It looks to be in very nice original condition. Some points from the video - the engine sounds fine (they are louder than present day machines). There was a small smoke plume on revving up but nothing to worry about - they all do it until warmed up. Turf tires are nice for the lawn, but not much for traction - they tend to reduce tractor value because swapping for ags is spendy. From the video the hydraulic down force of the loader appears to possibly be weak, although it was hard to tell from the very brief time the loader was in contact with the ground. If you can inspect this before the auction, raise the bucket and roll it down pointing toward the ground - then try pushing down and see if it lifts the front of the tractor at low engine rpm. It should pop it up without effort. If it does not, the pump could be worn out - $$ to fix.
    L345, L3250, L48, L5450, never enough attachments
  3. #3
    New Member
    Join Date
    Jun 2013
    Posts
    5
    Watertown, Mn
    Farmal C
    Thank you rbargeron.
  4. #4
    Join Date
    Jan 2012
    Posts
    1,870
    Success Missouri
    Kubota L3800DT, L3750DT Shuttle
    Yes, this series is Heavy Duty! Our old L3750 is 5 cylinder, 45hp, 3900 lbs. It's built like an old school 50+hp tractor. My dealer told me this was the start of the Grand L series.
    Don
    Kubota L3750 Hydro Shuttle, 4wd, FEL; L3800 Gear drive, 4wd, FEL
    Husqvarna XP chainsaws 346xp X3, 357xp, 562xp, 359
  5. #5
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,724
    Branson, Mo.
    Kioti DK35se Hydrostat
    The two things that stuck out to me were the turf tires on a loader and boxblade machine, and a very poor operator. He made no real attempt to lift the front end with the loader as he did not understand how to do so, and his clutch control was a bit lacking. I would bet the tractor is just fine.
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
Similar Threads
  1. kubota l3350 will not move and bucket will not work
    By bigrome in forum Kubota Owning/Operating
    Last Post: 09-21-2013, 08:23 PM
  2. kubota l3350 with bf800 loader problem
    By bartdrtrdr in forum Parts/Repairs
    Last Post: 08-05-2013, 11:28 PM
  3. 3-Point Hitch Kubota L3350 Three-point not lifting
    By tb183609 in forum Kubota Owning/Operating
    Last Post: 05-29-2010, 01:57 AM
  4. Kubota L3350
    By kenmissouri in forum Parts/Repairs
    Last Post: 04-24-2007, 08:59 AM
  5. Newbie question about a 1988 L3350
    By bobolie in forum Kubota Buying/Pricing
    Last Post: 11-10-2004, 02:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
