I was using a Woods tsg 50 stump grinder. Not covered under insurance.....
I take it there was no slip clutch between the tractor and stump grinder..? OUCH
not trying to be a smart Alec -
but- a good used 50+ hp 2 wheel drive utility tractor will probably be less expensive to get you up and stump grinding again- than the fix for that bx will cost???
that tsg grinder has some easily to be misunderstood specs
Product Details
at the top it lists tractor hp range of 50- 100 hp
- under general lists tractor engine power between 15-50 hp
also the notation of being compatible with a cat 2 hitch
It looks like that size of Woods stump grinder is a recipe for the destruction of any bx pto
especially if there is no slip clutch.. jmo
Hopefully the bx can be fixed , without major expense- or you are mechanically inclined and or have a friend that is good at working on these new Kubotas.
Good Luck- and your tractor will be good as new once fixed
but after reading the Woods specs- can't recommend running a tsg 50 on any bx series
