Buying Advice 2007 Kubota B3030
   / 2007 Kubota B3030 #1
sodak
South Dakota
Ford 8N
Hello! I am very close to purchasing my first tractor. It is a 2007 B3030HSD that has under 400 hours, industrial tires (60-70%), and a loader. The hydraulic pump was recently replaced by the dealer. I can get it for just under $13,000.
I have 13 acres, mostly open/flat land, with a tree grove and several trees that I mow around. Tractor will be used primarily to mow, haul compost / clean chicken coop with FEL, and to till a large garden, pumpkin patch, and hops yard.
3 main questions:
1. Is that a good deal?
2. Should I be concerned about using an HST for tilling or other ground work?
3. Given that I will mostly mow and till with it (I have a plow truck for snow), should I load the rear tires with Rim Guard for an additional $250?
For the mowing, I will probably buy a new RC72-30B MMM Deck (an additional ~$3500).
Thanks for your help and guidance!
   / 2007 Kubota B3030 #2
I'd think it would serve you well. Price prob not awesome but not horrible arround here.
I had a B3300su.You'll need to add weight for non-tilling ground work (more than just rimgard). Loading should be free as well as bucket hooks.
I think you'll be VERY unhappy with a MMM. A rear finish mower will be lots cheaper and way easier to take on/off.
   / 2007 Kubota B3030 #3
Each to his own, but a tractor of the size and larger starts getting too big for lawn mowing, in my universe. Everyone sees things differently and everyone's obstacles are different when lawn mowing too.
I'd rather mow with a lawn tractor. Nimble and dedicated to the job. That $3500 would buy a nice, nice lawn mower.
Changing between a B3030 as a field tractor and a lawn mower would be a PITA in my world. Again, each to his own. Loading is great for FEL work safety and for snow pushing. Not as great on the lawn. Perhaps we try to justify our purchase by thinking that the tractor can do this and this and this and that.
We're probably better off focusing on what a tractor does best. What a zero turn does best. What a lawn rider mower does best. Hope that helps a bit.
   / 2007 Kubota B3030 #4
I would say to #1-yes
# 2-no
# 3-yes
# 4- no to the mmm.
   / 2007 Kubota B3030 #5
1.) I sold my Kubota B3300SU tractor loader package, 406 engine hours, for $13,000 in January 2014. It was always stored in a humidity controlled garage.
I purchased it new in February 2012 for $17,200. The way I figure it my depreciation cost was $10 per operating hour. Cheap entertainment and a good reason to buy a new tractor every two to three years.
(Yes, I had fuel costs, service costs and one $250 KTAC insurance deductible on a FEL repair.)
2.) HST is IDEAL for roto-tilling. It is a rare Kubota 'B' that is not sold with HST.
3.) I did not load the rear R4/Industrial Tires of my B3300SU, however I did mount an implement on the Three Point Hitch as counterbalance whenever I expected to lift anything over 50% of loader capacity. Usually I ballasted with a Box Blade. Weight cantilevered behind the rear axle is more effective, pound-for-pound, than filling the tires. The front axles on 'B' tractors are light, you need to be careful not to stress front axle and front bearings overly much when carrying a heavy load in/on the FEL.
Liquid in the two rear tires has the advantage of lowering your center of gravity, improving stability at all times.
4.) Mid-PTOs to power MMMs are optional on most of the B's. Do you have one?
I'm not keen on MMM's. With an MMM mounted you have no ground clearance.
Once you get the tractor home you will discover dozens of uses for it.
A Ratchet Rake is extremely useful on a 'B' bucket. You buy RRs from the T-B-N store. Here are some U-Tube videos: https://www.youtube.com/results?search_query=Ratchet+Rake
As you are new to tractors, I highly recommend purchasing Kubota's KTAC tractor repair insurance: https://www.google.com/search?client=safari&rls=en&q=ktac+insurance&ie=UTF-8&oe=UTF-8&gws_rd=ssl
A Handi-Hitch will allow you to tow from your Three Point Hitch: HANDI HITCH
IMPLEMENT LINK: http://www.lsuagcenter.com/NR/rdonl...45263BDD8/11557/pub2917tractorimplements1.pdf
   / 2007 Kubota B3030
Great tips - I might get a Ratchet Rake right away. If I do not go with the MMM, what do you recommend as a good 72" finish mower?
   / 2007 Kubota B3030 #7
Lots of good used ones on CL. It will handle a 6ft fine.
   / 2007 Kubota B3030 #8
IMO a finish mower is vastly superior to a MMM. They are much cheaper. They are way easier to remove and hook up. They have better resale value because they fit most machines. They are easier to remove the blades. They can be lifted up out of the way for most work a MMM would have to be removed to to do. Pluses to the MMM is it is easier to mow in a tight place with. Some will tell you a MMM provides a better cut, but when compared to a good finish mower this is not true. A 72" finish mower will be fine for your tractor, but if it has drastic stick out from the rear wheels I'd go with a 60" mower. I have a Howse finish mower. It is a good heavy duty mower. The deck is 7 gauge steel and the mower weighs 750 pounds. It has a blistering fast blade tip speed of 26,000 FPM, yes you read that right and it wasn't a typo. It sounds like a dang airplane about to take off. My ZTR has a blade tip speed of "only" about 18,000 FPM.
   / 2007 Kubota B3030
Yeah, I'm really struggling on whether the MMM is a good idea - I do have a LOT of trees that require mowing around (as well as a lot of open area) which is why I initially wanted to go with the MMM.
That said, I suppose the HST + rear finish mower I assume will still be a great deal less painful than the 5' bush hog I am used to using on the family's old Ford 8N.
   / 2007 Kubota B3030 #10
Depending upon how many A LOT of trees are I'd recommend getting a good quality ZTR and skip mowing with the tractor.
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
Caterpillar GP40K Forklift (A52384)
Caterpillar GP40K...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
