ShowroomShine
Gold Member
The CS2410 does everything I ask it to, with the exception of the loader. The only thing I use the loader for is to move hay, and the small loader will neither lift enough or high enough to do what I want. I'm usually feeding large squares or small rounds which are less than 900lbs. the 2410 wont lift them and it makes life pretty difficult. The only other thing the tractor does is mow the yard, with some light box blade and finish mower work.
Thinking of the B2301, dont think the extra 2hp of the 2601 is worth the extra $1200. The loader on the B2301 should be large enough and high enough to move a 900lb bale, plus the whole tractor only weighs like 300lbs or so more than my CS2410 so it should still do fine on the grass.
Do you think the tractor would lift a 900lb bale with forks with relative ease? Wont be all the time or anything, we feed maybe 4-5 bales a year.
I'm looking for turfs, 60" deck, Loader with QA. What prices are you guys seeing on this combo? It has a $21,000 list. I was quoted about $18K from an online dealer, I feel like thats pretty high for this combo.
