plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,017
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I want to get some weight on the back of a Kubota L6060 to get full use out of the grapple and loader bucket. I was advised to get 1,200 lbs on the rear of the tractor for counterbalance, and to help keep too much weight off the front axle.
Loading the rear tires increases weight, but not weight behind the rear axle. So loaded tires won't help take weight off the front. So I need something on the 3pt hitch. There are some ancient "grandpa implements" scattered around the property, such as old rusting tillers or harrow. I could use these for ballast, but they are *large* and might snag up on things like stumps and other obstacles.
Is a ballast box the best solution for weight due to compact size compared to using an implement? And is there a source for a good ballast box that would mate up behind the L6060 cab model?
