Patk
Member
Hi All,
I've been lurking here for some time ironing out which tractor to buy and wanted to thank all for some geat insights on size, features, what gets used, what to add later, etc.
I settled on an L3130 HST 4WD, Filled R4's, LA723 FEL, QuickAttach, Std 72" bucket with toothbar and chain hooks (beefed up on top by dealer), Brushhog SBX650 boxblade, and an AnBo 5' grapple rake with electro-hydraulic switch added on the loader control valve.
The grapple is for the brush and small logs scattered about and my 9 acres and lots of other small pick it up, set it aside jobs...I'm sure I'll think of more. /forums/images/graemlins/laugh.gif
Let me say that it was a tough decision between this and the L4330. I wanted the large lift capacity of the LA853 to offset the 650# grapple, as well as the much better torque/$$ of the 4 cylinder 41HP engine. But in the end the $$ difference was too much. I figured the weight of the L3130 with FEL is around 600-700#'s lighter, but in low range, with calcium in the rears and some 3pH weight, the traction should be close to the same. If I'm dead wrong on thias topic, please don't tell me cuz i'll kick myself for not finding a way to swing the L4330. /forums/images/graemlins/mad.gif
I'm planning on adding 2 rear remotes and perhaps T&T a bit later, as well as a full L35-like ROPS cage shortly (big tree's with lots of limbs waiting to get even), but for this summer and the 'training' period, that's enough to work with.
I'll post pictures shortly.
Prior to this, I've owned 4 shovels and three wheel-barrows...it's been a long time coming.
Pat
Pat
