So I had the opportunity to actually try out the L3400 today. Had the dealer hitch'er up to an implement. I wanted to see what all the fuss was about. What a disappointment! I was expecting the tractor to hop all over the place. It didn't.
Picking up an implement, it did fine. Lowering the implement, it did fine. Lifting the implement just a little bit, it looked to lift the thing maybe a half-inch; maybe tad bit more, with each corresponding number labeled on the lift control. And that was if you slowly crept the lift up, which you don't in real life applications. Talk about control. Some have said that you couldn't finish grade with this lift. Actually, I don't see how you could get much more of a precise/incremental change in lift position with a lift that "feathers". Not to say that having a lift smoothly move up and down wouldn't be desirable, but I was under the impression that this thing was totally flawed.
Now I've spent a good many hours on tractors, mostly old with very worn out parts. I'd consider this thing a dream machine compared to any of the old traps I've run. Many times I've grabbed the lift lever to raise implement an inch or so when the darn thing started to dig to China, only to over pull because of delayed response and end up lifting my plow completely out of the ground. Talk about frustrating. I'd like to see how this machine performs in the field, as is.
I'd recommend that anyone considering it, try it out at home before having the dealer's mechanic tear into it to replace any valve. Especially when I think about 3-pt lift operation. Almost always, total up or total down.
