Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    New Member
    Join Date
    Feb 2012
    Posts
    8
    MF35
    Default Re: Tg1860 mower diagram
    Thanks,Pete
  2. #12
    New Member
    Join Date
    Mar 2013
    Posts
    1
    Georgia
    TG 1860G
    I need help with my tractor the belt start grinding on Its self when I lift the mower deck what can I do
  3. #13
    New Member
    Join Date
    Dec 2015
    Posts
    1
    Laytonsville
    tg1860
    Quote Originally Posted by uglyboywith11fingers View Post
    the pdf I posted is a view from the left front of the tractor...
    the tensioner rides on the left side, in the little bend in the belt just back of where the line from 150 points to.
    to get the tensioner over there, make sure you disengage the tensioner link that hooks on the bracket just inside the right rear wheel, you get at it from behind the tractor.
    once you get the belt & tensioner in the right place & the mower deck attached, just pull on that link from behind the tractor and hook it back in the slot in the bracket. it take a good pull because you're putting quite a stretch on the tensioner spring.
    Pete
    Can someone help with the tension spring attachment points? Is there more than one spring holding the tensioner because i can not figure out how to get the tensioner to apply tension to the belt with one spring. Does tensioner link attach to tension pulley bracket? Need a diagram of this particular area or pic if someone can help. Thanks.
    Tom
  4. #14
    Gold Member uglyboywith11fingers's Avatar
    Join Date
    Sep 2011
    Posts
    458
    Georgetown, Ontario
    2007 BX24TLB, 1998 TG1860G
    I also answered this on 'the other tractor forum'
    Tg1860 mower diagram-tg1860-belt-tensioner-jpg
    this pic should help, although it does not show the actual belt, the idler in this pic goes into the little bend in the belt in the other pic.
    Pete
Similar Threads
  1. Flail Mower BEFCO H80 Flail Mower Review
    By Dreamin_Tractors in forum Attachments
    Last Post: 06-05-2012, 10:25 AM
  2. Replies: 9
    Last Post: 01-26-2010, 12:36 AM
  3. Mower Trailer
    By frederic in forum Trailers & Transportation
    Last Post: 07-15-2005, 06:31 PM
  4. Rear Finish Mower Advice regarding rear finish mower
    By jcmseven in forum Attachments
    Last Post: 07-07-2005, 11:41 PM
  5. Finishing Mower
    By luoisz in forum Attachments
    Last Post: 03-28-2003, 02:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
